3.4 Drive train
Old Jan 18, 2009 | 08:51 AM
Sammyboy's Avatar
3.4 Drive train
So im the mits of detrmining whether i am going to under take a 4.3 or a 3.4 swap, on thing i cant quite seem to find is the 3.4 swap moddifacations.
what do i have to change to tranny, torqe converter, and flywheel wise?
Old Jan 18, 2009 | 11:53 AM
allnmstkn313's Avatar
Read the stickied buildups, and this http://www.offroadsolutions.com/tech.html#engine
3.4 is a fairly straightforward swap
Old Jan 20, 2009 | 04:05 PM
syber_kowboy's Avatar
If manual->pull 3.slo + 3.4
If auto -> pull 3.slo and 340H + 3.4 and T100 340R
Old Jan 20, 2009 | 06:54 PM
Sammyboy's Avatar
thanks for the links alln
Some other issuse iv found to the swap is do or will i accually need a donor vehical? or can i pull 3.4 + auto tranny out of a yard, along with a cpu?
Old Jan 20, 2009 | 10:03 PM
breknraj's Avatar
Having a donor vehicle is certainly handy, but not practicle for a lot of folks. If you just get your stuff from the yard, make sure that you get the ECU, the whole engine wiring harness, EVERYTHING attached to the engine, and the evap system.
That shoud cover close to all of the issues that you will encounter.
jasonty
41
Dec 23, 2018 01:00 PM
mengquis
Jul 13, 2015 10:39 AM
94whiterunner
Jul 12, 2015 07:15 PM
Poncho0206
Jul 10, 2015 06:21 PM
Jnkml
Jul 6, 2015 01:20 PM
