3.0 to 3.4 swap WIRING!!
Old Nov 23, 2008 | 07:09 AM
  #41
cartune777's Avatar
ill try it, hopefully ill get to drive it today
Old Nov 23, 2008 | 11:47 AM
  #42
screamer76's Avatar
congratulations!
Old Nov 23, 2008 | 02:02 PM
  #43
cartune777's Avatar
thanks, it runs good but the motor shakes like its misfiring or something, but all cylinders are firing.
Old Nov 26, 2008 | 05:20 PM
  #44
cartune777's Avatar
finally took it out for a test drive tonight, it runs like crap, spits and sputters, and the check engine is flashing, any ideas?
Old Nov 26, 2008 | 08:12 PM
  #45
RobD's Avatar
Are you able to pull codes?
Old Nov 26, 2008 | 08:28 PM
  #46
thefatkid's Avatar
The check engine light flashes when you are in danger of burning up your catalyst. The ECU determines this by misfire logic. Fix your misfire and the flashing MIL will stop.
As to why it is misfiring? You have confirmed spark at all cylinders? plug wires crossed (that is kinda hard to mess up 3 wires)? Good fuel? Injectors all connected?
Old Nov 28, 2008 | 02:23 PM
  #47
cartune777's Avatar
ill double check everything tonight, does anyone have a diagram of how the plugs wires go?
Old Nov 28, 2008 | 04:59 PM
  #48
neoworm0's Avatar
pretty sure it's 1 - 4, 3 - 6 and 5 - 2
Old Nov 28, 2008 | 06:56 PM
  #49
cartune777's Avatar
yup thats what i have, so im getting sparks on all cylinders, and i just tested the fuel injectors they are all working, im stumped, could a bad or non adjusted tps cause a misfire? or venting the pcv?
Old Nov 29, 2008 | 09:56 AM
  #50
cartune777's Avatar
fixed it i overlooked the wires, i had 2 plug wires crossed, runs great, thanks for the advice!
Old Nov 29, 2008 | 01:53 PM
  #51
RobD's Avatar
Well, what do you think now? Having fun yet?
Old Nov 29, 2008 | 05:59 PM
  #52
cartune777's Avatar
yeah its fun, ive never driven a 3.0 so i dont know how they compare, i just put a body lift in it, now time for the body work, its got the Michigan rust
Old Nov 29, 2008 | 09:25 PM
  #53
RobD's Avatar
Disconnect two cylinders...that will give you an idea what a 3.0 is like!
Old Dec 1, 2008 | 06:59 PM
  #54
cartune777's Avatar
drove pretty good today although i didnt get on it still no muffler
Old Dec 1, 2008 | 07:00 PM
  #55
UKrunner's Avatar
Where in Michigan are you?
Old Dec 1, 2008 | 07:23 PM
  #56
cartune777's Avatar
im in mt pleasant, why do you ask?
Old Dec 12, 2008 | 07:14 AM
  #57
cartune777's Avatar
does any one know how a cheap turbo muffler sounds on the 3.4, right know it has a flowmaster with 2.5 tubing, i really dont like the sound of it
Old Dec 13, 2008 | 10:30 AM
  #58
cadman's Avatar
The exhaust I used to pass inspection has a cheap glasspack on it and I think it sounds like exhaust coming out of ass. This exhaust only stayed on until I passed inspection and got my truck registered, but I hated every second I had to listen to it.
Now I'm running a Magnaflow and it sounds great. A nice throaty sound but not loud.
Old Dec 13, 2008 | 12:54 PM
  #59
cartune777's Avatar
haha what size tube are you running?
Old Dec 13, 2008 | 02:51 PM
  #60
cadman's Avatar
2 1/4" tube. If I do get the TRD SC I'll probably wind up redoing the exhaust.
