2000 A/T motor w/97 M/T wiring
Old Oct 8, 2009 | 09:45 PM
piche582's Avatar
Was wondering if I could use the M/T wiring & ECU off a 97 on my A/T 2000 motor? Any sensors/parts that I need to steal off the 97 motor that have different plugs then what comes on the 2000 motor? Gonna be diving into my swap in a few weeks & can't afford to have my truck down for too long. I'd use the 97 motor, but it's got 200K on it vs. the 80K on the 2000. I have the whole wrecked 97 4runner so parts off it are no problem, but only the loose 2000 engine/wiring laying around
Old Oct 9, 2009 | 07:21 AM
BIG RON's Avatar
nope your good, I swapped the wiring from a 97 to a 2003 motor with no prob. I just had to change the throttle bodies the 03 was electric.
Old Nov 1, 2009 | 05:53 PM
dntsdad's Avatar
hey Ron I have a question on this.
Are you saying that you had a drive by wire (electric) throttle body and simply changed the throttle body to an older, cable driven throttle body and all worked well.
I found a 2001 Runner for a donor i think, but I am thinking that new would be drive by wire so i have been avoiding it. If its simply sourcing an older throttle body and replacing , then I will look into it more.
thanks
Old Nov 1, 2009 | 06:11 PM
chopperbob04's Avatar
the 2001 3.4 is cable control.i am in the middle of a 2001 3.4 swap.pretty simple swap with help of all the theads on here.
Old Nov 1, 2009 | 07:11 PM
dntsdad's Avatar
Since the hijacking of thisthread has begun......I am takin it over.
ChopperBob....what are the paticulars of the target vehicle.
I have 92 3.0 excab 4x4 manual. Curious as tp what you have. Hopefully you are taking pics and making your own thread. I'll go look for it.
Old Nov 2, 2009 | 05:58 PM
sorry for hijacking this thead.
dntsdad....I have 92 excab 4x4 Mt 3.slow..
just about to drop the 3.4 in but still waiting on some parts.
_____________________
1992 Toyota Pickup
excab sr5 4x4
3.slow 356k
Old Nov 2, 2009 | 07:31 PM
dntsdad's Avatar
right on!!!!......I have the exact same vehicle. I shall watch for your thread that I know that you will make documenting every minute detail of all your hard work and figuring things out..........and then copy it all!!!
Old Nov 4, 2009 | 01:04 PM
GJCruiser's Avatar
Big Ron,
Which O2 sensors did you use- 97s or 03s, or does it matter?
Thanks
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
msane99
Jul 17, 2015 10:13 AM
Avenged
Jul 9, 2015 07:55 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
