"Warming up an engine"
Old Dec 19, 2003 | 08:05 AM
  #41
rwmorrisonjr's Avatar
From: Home: Aurora, CO; Work: The People's Republic of Denver
BTW, just ordered mine for $36 from the local dealer, so the challange I posted in the "OEM/TRD" thread is now void for Mr. lowlowprices!
Old Dec 19, 2003 | 08:15 AM
  #42
its2slo's Avatar
ha ha, im wondering if its cash only when you buy from him :pat:
Old Dec 19, 2003 | 08:25 AM
  #43
rimpainter.com's Avatar
Originally posted by WileEToyote
1. Start engine, throw AC on with defrost, full bore
On the 5VZ the AC automatically runs with the defrost selected.
Old Dec 19, 2003 | 09:03 AM
  #44
Beartracker's Avatar
AC and heater?
Why is it better to run the ac and the heater? What about running it with the button on for inside air ? it seems to blow alot harder than with the ac on.
Old Dec 19, 2003 | 09:07 AM
  #45
It is better to run the AC and the defrost, not the AC and the heater.
Old Dec 19, 2003 | 09:44 AM
  #46
ewarnerusa's Avatar
Really? How hard was it? Do you have pics & a writeup?
ya, it's in the form of a $200-some invoice
You need to remove one of the freeze plugs from the block. All the info I could find led me to believe this meant drilling and tapping it, so I left it to someone who could be held more
[/QUOTE]
Mine installed from the dealer was around $85. It is as you described above, but I believe it is simply unplugging the freeze plugs and plugging in the block heater plug. I think it is easy, but I didn't do it myself.
Also, I believe the A/C is good during defrost because A/C acts as a dehumidifier. That's why your nose always dries out when you've been in an A/C'd environment for a long time. So A/C during defrost helps to lower the humidity level in the vehicle and prevent fogging.
Old Dec 19, 2003 | 10:20 AM
  #47
Mohamed's Avatar
It keeps the engine coolant & block warm enough in sub-freezing temps so that when you start the engine, all the engine fluids will start circulating faster & prevent engine wear/possible part breakage. If your Tundar has one, look for a three-prong electrical plug sticking out from or secured behind the grille. Unless your truck came from the frozen north, its highly doubtful that you have one. As for the Accord, it has an aluminum block so it will cool down faster than a cast iron one.
aaahhhh, got ya. No, my TundAR, hehe, has it, it's part of a "cold weather package" that was like $200 extra on the sticker. As far as my accord, there is one that sells for like $40 I might buy, and install. Thanks for the info .
On second thought (or research), it's called the "All-Weather Package" and it has something called a heavy duty heater. I wonder if it is indeed an engine block heater?
Davebarbier
Nov 3, 2015 03:28 PM
gentry
Sep 28, 2015 06:16 AM
bhaithc
Sep 17, 2015 07:53 PM
sanctfy
Sep 13, 2015 06:33 PM
--Oz--
Sep 6, 2015 01:06 AM
