VSS location
Old Apr 28, 2005 | 07:24 AM
bryan's Avatar
VSS location
Can anyone tell me where the VSS vehicle speed sensor is on an 89 4Runner with a V6 and 5spd. Thanks and a picture would be great.
Old Apr 28, 2005 | 10:54 AM
Robinhood150's Avatar
Probably where your driveshaft goes into your transfer case or tranny, depending on whether you have 4wd or not. If you search for vss or speed sensor or something, you'll find a picture of mine for my auto tranny. But then again, mine is electronic and yours is cable.
Old Apr 29, 2005 | 01:27 AM
Greg'sToy's Avatar
it's in the cluster. when mine was bad, i installed the spare cluster that i had, and problem solved. are you getting a check engine light, and code 42?
Old Apr 29, 2005 | 05:29 AM
bryan's Avatar
Yes I am getting a code don't remember right now which one but it said VSS. Also my crusie control doesn't work. I thought it was in the cluster thanks for the help. Bryan
Old Apr 29, 2005 | 07:03 AM
Greg'sToy's Avatar
mine did the exact same thing, no criuse, code 42, CE would come on...
Old May 2, 2005 | 09:43 PM
4Crawler's Avatar
On the earlier trucks, it is attached to the back of the speedo where the speedo cable attaches. Basically senses speed off the spinning mechanical speedo cable. Later models went to an elctronic sender in the t-case and then wires up to the dash.
Old May 4, 2005 | 06:16 AM
bryan's Avatar
I put a new speedo in and still have the same VSS code. Time to due a little more searching. Thanks for all of your help Bryan
some drunk guy
Aug 3, 2021 06:09 PM
tyzsdaddy
Jan 16, 2016 09:19 AM
I8URSVT
Oct 5, 2015 05:42 PM
dropzone
Sep 13, 2015 11:18 AM
