Tire tools
Old Jan 3, 2003 | 05:16 PM
scott.475's Avatar
Tire tools
Anybody have any experience, or seen in use, either the R and R Beadbreaker ( http://www.randrbeadbreaker.com ) or the Extreme Outback Tyre Plyers ( http://www.extremeoutback.com ) ? I am thinking that for about $250 these might not be a bad investment. Could change tires at will, then only have to pay for balancing!
Old Jan 3, 2003 | 08:32 PM
alanh's Avatar
I think I've seen reviews of both on the web. You should be able to find them with a bit of searching. I think the R & R beadbreaker is a little easier to use since it doesn't rely on brute strength as much, but it may be slower.
In either case, I personally wouldn't use them as an alternative to a tire shop but they would be insurance for travel out in the wilds if you think you might end up with two flats.
I think they would just be too slow for normal use unless you're really trying to cut costs and you do a lot of tire changing.
I tend to have a set of tires put on and there they stay for several years until I need to replace them or get a flat repaired (which always seems to end up being a replacement anyway with my luck). It would take me a long time to recover the cost if that was my objective.
Alan
BushPig
Oct 29, 2022 06:26 AM
djpg2000
Nov 11, 2020 04:56 AM
RobotMoose
Sep 2, 2015 05:53 AM
58rennur4
Aug 4, 2015 08:49 AM
skoti89
Jul 8, 2015 12:05 AM
