Timing Chain and Guide Replacement
I have a 92 Toyota 4x4 with a 22RE. I have owned the truck since brand new. It has been a awesome truck! Currently the truck has 99K miles on the motor.
My question is: Is it time to replace the guides and timing chain?
Jonathan
92 Toyota 4x4 22RE
03 Tacoma 4x4x4dr.
98 Toyota Camry
You can see I am stuck on Toyotas!
Jonathan
92 Toyota 4x4 22RE
03 Tacoma 4x4x4dr.
98 Toyota Camry
Jrallan26 My opinion from others is to change it . The best decision is to go for the LCE double or single chain or DOA racing version.They both have the latest metal guides that would outlast the stock ones.
Yeah, I remember reading taking off the valve cover and with a flashlight you can inspect it. I knew mine needed replacin with 136k on it they looked like this:
As for the LCengineering and/or DOA racing guides.. Try ebay. They are alot cheaper there. I didn't have time to order some cause of the short schedual that me and my dad have to do things so I just replaced them with the plastic ones. I figured if they lasted 136k they will last another.
This post should be helpful too
Badger62811
Jun 26, 2015 09:26 PM
1980, 22re, belt, chain, doa, engineering, guide, inspecting, lc, pontiac, replace, replacement, sunfire, timing, toyota
