Throttle Body Question
Old Aug 14, 2004 | 07:14 PM
Pretacopower's Avatar
Well I attempted to clean my TB the other day but ran into a problem...
I bought a can of TB cleaner and it says,
"With engine off, remove air-intake hose at manifold. Start engine and with engine running, spray cleaner in TB while working butterfly vavle back and forth manually...."
Problem is, when I disconnect the air-intake hose and try to start my engine, the engine won't start. It cranks, but stalls as soon as it fires. Any ideas?
Old Aug 14, 2004 | 07:18 PM
Mossback74's Avatar
That's because the MAS is not sensing any air flow. Just hose out the TB and use a tooth brush to scrub it up. Run some seafoam through too for kicks and giggles.
Old Aug 15, 2004 | 03:36 PM
Jeffires's Avatar
I cleaned my 3.0 by removing the air intake hose and putting my hand over the intake. Allow air to pass between your fingers and stick the straw of the TB cleaner through. Give some throttle and spray. This allows the engine to run while spraying.
Old Aug 15, 2004 | 05:11 PM
Thanks for the tip, I'll have to try that.
I'm afraid of Seafoam
Old Aug 15, 2004 | 06:59 PM
blink's Avatar
hehe... it works great. Just be sure if you run seafoam to have a new set of spark plugs. It turned my plugs plack
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
montanatruck
Feb 26, 2017 07:07 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
raiderhawks00
Jul 8, 2015 06:23 PM
