Strange "pshh" sound from engine
Old Jun 16, 2005 | 06:28 PM
fo_runner's Avatar
When I attempt to start my 3.0, it turns then makes a strange "steam engine puff" from the passenger side of the engine bay. When the engine starts, it continues making this sound constanly, but not as loud as before. When I accelerate, I can still hear it, like a high powered steam engine
What is the source to my problem?
Old Jun 16, 2005 | 06:31 PM
Silver_Truck's Avatar
maybe exhaust leak...check the manifolds and the crossover gasket...also check for a coolant I dunno
Old Jun 16, 2005 | 06:42 PM
fo_runner's Avatar
It's pretty loud when I crank the engine. Its sounds similar to an BOV (blow off valve).
It might be a vacuum leak; this problem started ever since I "attempted" to change my pcv valve. I couldn't get the hose to go on the PCV valve completely. Engine vacuum might be pushing the small valve, causing the noise.
Old Jun 16, 2005 | 08:03 PM
dragon564's Avatar
It seems as if you have answered your own question.......
Old Jun 18, 2005 | 06:33 PM
fo_runner's Avatar
I just solved my problem; the # 3 spark plug was loose and when I took it out; it was white. Must be the unburned fuel. So I wiped it down, put the spark plug back in, and started her up. No noise is coming from it now, and I have more power on tap.
Old Jun 18, 2005 | 08:53 PM
kevin444's Avatar
Are you trying to hide the fact you have a BOV that your not telling us ahaha kidding!
Old Jun 19, 2005 | 07:17 PM
fo_runner's Avatar
A BOV on my 4runner. Thats a rarity dude
Charecter1
Nov 6, 2023 10:08 AM
BushPig
Oct 29, 2022 06:26 AM
sandyota
Feb 4, 2021 11:16 AM
Eggslinger
Jun 8, 2019 03:32 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
