Sticking gas pedal...
Old Feb 29, 2004 | 04:29 PM
LevZeppelin's Avatar
My brother drives a 93 single cab 2wd manual truck. I was driving it the other day and i noticed that when i started the car and then went to drive the gas pedal was stuck down a little. i could pretty much start driving by just letting out the clutch it was giving it enough gas. It was worst when starting the car, but occurred slightly at stops such as traffic lights. If i would just push in the pedal it would go back to normal. I was wondering if this is a problem he should worry about or ignore. Im just wondering if anyone knows what would be involved with fixing this. thanks -aaron
Old Mar 1, 2004 | 03:22 PM
Nic's Avatar
Nic
It could be that the throttle body is sticking and needs cleaning. Simple to do. Check the link below:
https://www.yotatech.com/forums/show...+body+cleaning
Old Mar 1, 2004 | 04:20 PM
Glenn's Avatar
Sounds like what happened to me. A thorough cleaning of the throttle body cleared the problem up.
nvdesertrunner
May 11, 2020 08:18 PM
bfmcelroy
Aug 18, 2015 06:42 AM
pyramid
Jul 30, 2015 10:05 AM
D.B.T. 87 4x4
Jul 20, 2015 04:51 PM
