Starting Problems when Engine is Cold
Old Apr 18, 2005 | 05:49 PM
Cooper04's Avatar
I have a 1996 Toyota 4Runner 3.4Lv6 with 196,000 miles on it. I am having problems with my truck starting when the engine is cold. It takes four of five rotations for the truck to start and it sputters before it runs correctly. This incident comes and goes whenever the engine is cold. I was also wondering if you are supposed to hear the fuel pump running if u use an aftermarket fuel pump(Master) on a 4runner? Thanks a lot for your help
Old Apr 19, 2005 | 04:58 AM
YotaJunky's Avatar
Try pulling your cold start injector and clean it out with brake fluid if it looks clogged up with carbon deposits. Careful that you don't over torque when replacing the mounting bolts.
Team420
Jan 12, 2021 04:57 PM
vasinvictor
Jan 20, 2016 12:39 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
jmc88runner
Jun 18, 2015 03:39 PM
scott
Jul 15, 2002 07:56 AM
