Starter problem
Old Nov 20, 2003 | 10:44 AM
Badmice1's Avatar
Exclamation Starter problem
Hello there:
I'm suspecting that my starter is goin' out (It takes 3-5 turns/clicks before I can start my vehicle). I've done my research in the forum & that seems very consistant with other member's observations.
My question is --> How can I tell if it is a starter problem vs. a starter CONTACT problem? I've read other posts that this may be a starter contact problem, but I don't know how to systematically diagnose it.
Here are my starter symptoms:
1.) I turn the ignition 3-5x, all clicks, and then the starter turns over.
2.) If I run the car for > 1hr, problem #1 is gone (at least temporaily)
3.) If I let the car site for > 3 hrs, problem #1 reoccurs, and I repeat the process.
Any input is appreciated! Thanks!
Alan
Old Nov 20, 2003 | 12:52 PM
hypnotoad's Avatar
if it clicks then the solenoid is engaging but there's no juice (or not enough) to turn the motor; sounds exactly like contacts to me
dunno how to diagnose on the car, but when you take it off and look at the contacts it should be pretty obvious
Personally, I take advantage of a situation like this to replace the whole part - if the contacts are shot it's likely the solenoid will go at some point. Dunno when, but why get in there twice?
Old Nov 20, 2003 | 01:10 PM
Badmice1's Avatar
Hyp-Toad.
Thanks for your input. I pretty much came to the same conclusion, but I was really trying to avoid dropping $150+ during the holiday season for a new starter!
I neglected to mention something else (it may or may not be relevant)...
When I bought the car from the previous owner, the car was equipped with a Clifford security system, which has a button that allows me to start the vehicle remotely (ie without the key in ignition, I just press a button). Now...when this starter problem occured, I tried to start the car via that route, and the starter just click...ok...same as if I used a key...
Here's the catch... When the vehicle turns over and starts with this remote, the starter makes this screeching noise, as if I held the key in the "start" position if the key was in the ignition....
That was a flag to me that something may be wrong with the security system? Your opinion?
Thanks again!
Alan
Old Nov 24, 2003 | 12:14 PM
metalhed's Avatar
EASY FIX
Greetings You might check here http://4crawler.cruiserpages.com/4x4.../Starter.shtml
Roger has an extensive write up and it is easy to follow. Hope this helps
Old Nov 24, 2003 | 12:50 PM
Badmice1's Avatar
Hey Metalhed - That helped! Thanks for the reply!
A+
Old Nov 28, 2003 | 05:46 PM
Badmice1's Avatar
Update - I got that heavy piece of used-to-work starter out of my car & in wit a new one. The write ups were great. It took awhile to find all the pieces to remove, but that worked out fine.
The hardest part is really removing the starter from the little space between the suspension & the body and sticking the new starter back through the same spot.
Good job on the write ups!
Peace
Alan
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
clok
Aug 1, 2015 09:42 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
ZONAYODA
Jul 13, 2015 07:17 PM
colinmil
Jul 6, 2015 04:03 PM
