Speedo Whine and whoopie cushions
Old Apr 3, 2005 | 10:47 PM
GA95Runner's Avatar
Exclamation Speedo Whine and whoopie cushions
Over the winter, my speedo started whining badly...how easy is it to get to the tach cable to lube it? or is that even the right thing to do? has anyone else had this problem?
Another thing that is 'unique' to my 1995 V6 is there is a noise that can only be described as one similar to a 'blowout valve' I have found the spot where the noise is coming from every time i get off the accelerator, but have no idea what purpose the piece has...there appear to be 4 holes for bolts that are missing, but the piece is still in place and 'whoopie cushins' once off the gas...very strange
Old Apr 3, 2005 | 10:51 PM
green91runner's Avatar
the search button will help you here.. been coverd LOTS..
here's a how to..
https://www.yotatech.com/forums/show...ighlight=spedo
Old Apr 3, 2005 | 11:22 PM
bike4miles's Avatar
I't has been my experience that lube doesn't help. Just get a $15 replacement cable. Install isn't too bad, the hardest part it poping the gauge cluster out. It took me less than 2 hours to install mine.
Old Apr 3, 2005 | 11:24 PM
GTE4runner's Avatar
Yep, it's probably the speedo cluster going bad not the cable. It's not too hard to replace. Gotta love ebay...
Old Apr 5, 2005 | 07:21 AM
YotaJunky's Avatar
Before you decide to get a new cluster, test out the cable first. Disconnect the speedo cable from the cluster, grease it and then reattach it to the cluster. Drive around and listen. If there's no more noise, it's the cable. If there is still noise, it's probably the cluster. I regreased my cable on 3 separate occassions because the noise came back after about a week after each greasing. I finally gave in and replaced the cable, which was about $100 (Canadian) for the part. It's been 3 weeks now, and NO more NOISE!!
Troy
Old Apr 6, 2005 | 07:22 AM
GA95Runner's Avatar
the strange thing is that I only get the whine when its cold out, and I am just starting it up for the day.
Old Apr 6, 2005 | 07:25 AM
had the same thing.. when it was -40 in the winter.. if i hit above 30mph it was SO loud.. couldn't hear my stereo. once it warmed up, went back to a fairly quiet noise.
Dieselmann
Feb 19, 2019 02:57 AM
I8URSVT
Jan 15, 2016 07:25 PM
charlie_fong
Sep 27, 2015 10:06 PM
83
Sep 27, 2015 04:13 PM
Higbee89
Aug 27, 2015 06:52 AM
