removing skid plates on 03 4Runner for oil
Old Sep 5, 2003 | 03:56 PM
ron717
Guest
Posts: n/a
Does anyone know how to remove the skid plates on the 03 4Runner, to get to the oil filter and oil drain plug
Its a V8 4Runner 4WD
Old Sep 12, 2003 | 06:31 PM
EricM's Avatar
I splurged and bought the factory service manuals... lots of useful info. I haven't had to change mine yet (only 1200 miles on it) but according to the service manual, you only need to remove the front skid plate ("Engine Under Cover Sub-Assy No. 1"). There is a grommet ("Engine Under Cover Seal No. 3") under the oil pan that you can remove to access the drain plug.
Old Sep 12, 2003 | 06:36 PM
EricM's Avatar
Forgot to answer your question about exactly how to remove it...
It appears to be held on with 4 bolts... the rear two are recessed as the mounting surface is actually bracket attached to the plate. I'll be changing mine in a few weeks (I change every 2K) and I'll let you know what I find.
Jun 1, 2021 01:51 PM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
CJ94yota
Jul 3, 2015 10:14 PM
