Re-torque what...-- service Question (yes i searched)
Old Apr 3, 2005 | 06:25 PM
gomezza's Avatar
Hello all... I did a search and could not find my answer. I just finished my service and the only 2 things i did not do are... 1. "retorque propeller shaft" 2. Re-torque drive shaft flange bolts. Anyone know what they are torqued to and where these bolts are!? Thanks guys!!!
H-
Old Apr 3, 2005 | 06:36 PM
Bigblock's Avatar
there are 4 bolts in each end of the drive shaft.tighten them as tight as you can get them and tighten them some more!Mine come loose regular!
Old Apr 3, 2005 | 07:09 PM
gomezza's Avatar
you're kidding right? There has to be a reason they say "torque"... just like you can damage ur rotors by over torquing the lug nuts! Anyone know the specs to the bolts?
Old Apr 3, 2005 | 07:33 PM
frankenrunner's Avatar
Guest
it's 54 ft. lbs on 4x4's &/or 56 ft. lbs. on the 3VZ-E engined drive shafts.
-f-
Old Apr 3, 2005 | 07:36 PM
Ironmike4x4's Avatar
Specs
I am assuming you are talking about the torque specs on your '99 Runner so here goes.
Prop shaft at 54 ft.lbs.
Flange bolts at 54 ft. lbs.
This is according to Alldata.com so if it's wrong I assume no responsiblity. I personally think the Propshaft bold is supposed to be more but at work I use whatever the specs says for liability reasons.
Old Apr 3, 2005 | 08:29 PM
gomezza's Avatar
have a lot of you noticed the bolts on your 4runner's in need of torquing?
Old Apr 3, 2005 | 08:43 PM
Nic's Avatar
Nic
When I removed my driveshaft a while back, I was going to re-torque them back to spec. But, its was so darn difficult (if not impossible) to get a torque wrench on the bolts, I just gave up and tightened them the old fashioned way.
Old Apr 4, 2005 | 09:29 AM
miket223's Avatar
Hah, torque. That's funny. Every tech including me in the Toyota shop I work at uses the 1/2" impact until it stops spinning torque setting.
Old Apr 4, 2005 | 05:58 PM
gomezza's Avatar
hehe I dunno if thats a good thing for its life span... Sure hope my dealer didnt do that!
colasurdo
Jan 11, 2026 08:10 AM
stock87yota
Jul 31, 2015 10:08 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
