View Poll Results: What OIL are you using?
Amsoil
71
16.40%
Redline
1.85%
Royal Purple
1.39%
Mobil 1
172
39.72%
Castrol Syntec
44
10.16%
Non-synthetic
132
30.48%
Voters: 433. You may not vote on this poll
POLL: What oil do you use??
Old May 13, 2003 | 04:33 PM
Toyota Punk's Avatar
I use whatever the dealer puts in, I believe it's Mobil 1. If I had any place to do it I'd change the oil myself, and if I had any money I'd be using full synthetic but alas, I'm poor and drive too much and live in an apartment.
Old May 13, 2003 | 04:34 PM
PutzRunner's Avatar
Red face
In the 97 4Runner I use 5W-30 Valvoline
In the 00 Avalon I use 10W-30 Valvoline
I have had great service from Valvoline products and long engine life.
Old May 13, 2003 | 09:19 PM
XtremeOff-Road's Avatar
Originally posted by waycan
More Questions for you guys using Amsoil. Which of the amsoil oils are you using? If I remember correctly they have at least three types. Also are you using the extended oil change intervals as they recommend. If so, do you change the filter part way through the interval?
Hey bud, this is the one you will want to use...You can click here
Mike
Old May 14, 2003 | 03:20 AM
Bob K's Avatar
Mobil 1 5w30 with K&N oil filter. I like the fact that I can use a 1" wrench or socket on the filter. I find it much easier in the tight space than using a filter wrench.
Old May 14, 2003 | 09:58 AM
  #25
beachtaco's Avatar
Originally posted by Bumpin' Yota
Valvoline HiMileage 10w40
same here. i use valvoline max lift 5w30 in my 4runner with fram 2x oil filter. i was using mobil 1 supersyn 5w30 but valvoline was cheaper this time around. i plan on switching back to syntechic, probably amsoil in 6 months.
i ran amsoil 5w30 syntechic motor oil with an amsoil filter in my old taco. i changed the oil filter every six months and the oil itself every 12 months. no problems.
Old May 14, 2003 | 10:57 AM
  #26
runningman's Avatar
Post OIL
Good ol dino. I noticed a few guys switch between synthetic brands, or atleast imply they do. This is very bad for the vehicle, you should never swtch synthetic brands once you've chosen one you should stick with it. With synthetics the way they protect essentially is the same but the detergents and compounds are so different that you shouldn't change up.
Old May 14, 2003 | 11:06 AM
  #27
Twisted4runner's Avatar
First off you should not have to use a filter wrench you oil filter should be hand tight and i promise it wont leak you should be able to remove it by hand this is why most of them have a little grip tape type stuff on the end
Old May 14, 2003 | 11:11 AM
  #28
you guys really dont need to run synthetic in your toyotas unless you are in a pre runner going 150mph accross the dessert
you are just wasting money when you could get other cool toys for your toy
look up the designed applications for a full synthetic or even a blend synthetic oil
Old May 19, 2003 | 07:58 AM
  #29
naksukow's Avatar
Redline w/ lexus oil filter. 7500 miles b/t oil changes
Old May 19, 2003 | 08:05 AM
  #30
PY
VALVOLINE SYNTHETIC 10W-30
fram 2x filter
My other Toy is a 1980 4X4, 20R 4 speed, with 31X10.5-15's, 320,000 miles, downey headers, K&n filter at 80,000 miles, aquired truck at 38,000.
IT STILL SCREAMS! Uses oil only after sitting for 6 weeks or more.
Old May 19, 2003 | 09:18 AM
  #31
data's Avatar
Senior Member
Mobil 1 w\ Mobil 1 filter. I'm a "Mobil" type of guy I guess.
Old May 19, 2003 | 05:27 PM
  #32
FUGGRWE's Avatar
Is the Valvoline Full Synthetic just as good as Mobil 1? A mechanic told me to jut use Mobil 1 because there are too many companies that claim to be just as good. We all know Castol Full Synthetic is a waste of money.
Old May 19, 2003 | 06:04 PM
  #33
PY
After a lot of research over 2 decades and through personal experience I've rejected Mobile 1 for motor oil mainly because Modile 1 tends to reject heat. Don't get me wrong-it can take a lot heat-far more than any dino oil and just as much as any other synthetic-but it tends to insulate, thus failing to provide one of a motors primary means of cooling off. This places a greater heating load on the engines cooling system, and in a hot climate and/or racing, every bit of cooling capacity helps. I took note when one guy had been studying synthetics to use in air cooled engines and found most of them rejected heat just like Mobile 1, and since an air cooled engine is cooled primarily by the oil, it caused those engines to overheat quickly! He waited serveral years for Valvoline to come out with a synthetic, and when they did he tried it and it worked. Subsequent studies revealed that Valvoline had apparently done their homework before coming out with the product and engineered it correctly to absorb heat.
But this was the late 80's. I haven't kept up with the progess, They all may be correctly engineered now, but I stick with what I know works.
I've lived in deep south Texas for years, and can say that I noticed a difference in engine cooling in the summer when I switched from Mobile 1 to Valvoline.
There's a lot of good stuff on the net now-a-daze I'm sure, so you may want to do some of your own research.
Just my $0.02!
Old May 21, 2003 | 08:32 AM
  #34
mkool's Avatar
Mobil 1 Full Synthetic, 5w-30. I follows same grade oil.
Old May 21, 2003 | 09:40 AM
  #35
DavidO06's Avatar
I use the AMSOIL 0-W30. They say it will last about 20,000+ mi., but i usually change the filter every 4-5k and the oil every 8-10k. Works pretty well for me.
Old May 27, 2003 | 11:30 AM
  #36
Gbost's Avatar
Talking
Quaker state 5W/30 full synthetic
Old May 30, 2003 | 05:30 AM
  #37
EOD30's Avatar
Amsoil 10w30 w/ amsoil filter
Old Jun 3, 2003 | 10:08 AM
  #38
Brown's Avatar
dinosaur remains
I use Castrol 10w-40 in my truck. I also use Toyota filters.
I change the oil every 4000-5000 miles. I would consider synthetic if I had a brand new Toyota, but I don't, so I won't.:pig:
Old Jun 4, 2003 | 04:05 AM
  #39
CLin9383's Avatar
mobile 1 10w-30 super syn
Old Jun 21, 2003 | 07:55 AM
  #40
Chevron Delo 400 15w-40 w/ factory filter. Changed every 5k. Its a dino oil used in diesels. I use Royal Purple in the drive train. Best combination I've found since getting my Runner at 187k in 2000. Now has 277k and runs like brand new!
Synthetics are great. Just be sure to be consistent. and to really be sure do an oil analysis. Some oils can go 10k before needing a change.
