Oil Use
Old May 6, 2003 | 06:37 PM
KING's Avatar
Oil Use
I currently have 99K on my 94 PICK-UP TRUCK.......
I've been using 10W-30 and for winter 5W-30, but now that I am about to surpass the 5 digit figure, I was thinking maybe I should start going with heavier weight, such as 15W-40, or should I go with straight 30?
Any suggestions?
Old May 6, 2003 | 09:11 PM
HBoss's Avatar
Well I don't consider that really, really high mileage and you'd probably be fine sticking with 5W-30.
If you want to be a little nicer to it you can try 0W-30 or even 0W-40 (if available) I wouldn't go 15W though, because that means it's thicker when you cold start it, so it won't lube as well on startup meaning more wear & tear on your engine in the end.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Toyvana
Jul 29, 2015 10:47 PM
yourrealdad
Jul 29, 2015 11:08 AM
irritech
Jul 27, 2015 05:15 PM
calderp
Jul 27, 2015 09:58 AM
