maitnence questions: ignition and fuilds
Old Jan 13, 2004 | 08:21 AM
Nolan's Avatar
I am going to be doing some maitnence soon and I had a few questions.
The first is what kind of oil does my manual transmission and rear differential take? Remember I have a 4cylinder 2.7L. Is there anything special to consider when changing the fluids. As far as I know you just drain it and fill it.
The second is with my ignition system. I am going to change the plugs, wires, cap, & rotor (yes i have a distributor). What kind of plugs and wires should I use? I am considering buying from this site and get the "traditional spark plug" or "v-power" and the "premium wire set." I have heard that Toyota ignition parts are good, should I go for factory parts over these? Will any cap and rotor from Napa or Autozone or should I go with factory for this as well.
And as far as changing the ignition parts, anything special that I should look out for (i.e. things I can mess up on)?
thanks a lot everyone!
Old Jan 13, 2004 | 08:26 AM
MTL_4runner's Avatar
I would use OEM parts only for the ignition but others may beg to differ
Old Jan 13, 2004 | 08:39 AM
cubuff4runner's Avatar
The OEM parts should work fine unless you plan on adding some type of high voltage coil. As far as plugs only use NGK or Denso each of these makes special plugs such as platinum and they ussually work fine.
Kamaloha
Oct 16, 2015 05:13 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
voiddweller
Sep 28, 2015 11:21 PM
Rickstwowheels
Sep 18, 2015 03:48 AM
