Maintenance light
Old May 11, 2005 | 08:17 AM
obxfishn's Avatar
Maintenance light
The maintenance light came on at 10000 mi. on my 2004 Highlander. Is there any way to turn it off without going to the dealer?
Old May 11, 2005 | 10:09 AM
boogyman's Avatar
Talking
"maintenance light"?? like check engine light? if it's the check engine light, you can go to autozone and get a code reader to check it. but since you're only at 10,000 mi, you're under warranty and should take it to the dealer
Old May 11, 2005 | 10:33 AM
PirateFins's Avatar
Try this its for a different Toyota but it might work. Also check the owners manual, it might be in there.
with the car key on ACC, set your odometer on mileage(not trip a or b) then turn ket off. then hold they button that switchs from odo and trip, then turn the key back to acc. while you are holding it down you will notice the maintenance light blink and go out. and then you are done.
ashersullivan88yota
Jan 18, 2022 05:37 PM
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
Odin
Jul 15, 2015 09:28 PM
colinmil
Jul 6, 2015 04:03 PM
