Looking for better gas mileage
Old Jan 13, 2003 | 11:54 AM
DrummerDaveB's Avatar
I posted this question in the other board but nobody has answered:
Can anybody tell me ways to improve my gas mileage on my bone stock 3.4L 4Runner?
Thx,
Dave
Old Jan 13, 2003 | 02:13 PM
ALBPM's Avatar
For starters replace the stock muffler with a Dynomax or Magnaflow muffler.
Do a search on either one, this has been a hot topic but those are the top 2 choices for an inexpensive exhaust upgrade.
Good for 1-2 MPG !!
Old Jan 13, 2003 | 03:50 PM
HBoss's Avatar
You can try:
-lightening the load in your Runner (any way you can)
-increase tire pressure
-clean or replace your air filter
-change the spark plugs
-try a fuel injector cleaner additive
-believe it or not, synthetics in your engine & diffs may improve mileage as well
-clean your MAF sensor
-replace oxygen sensor(s)
I'm sure there's more you can do, but here are some things to get you started.
Al
Old Feb 11, 2003 | 03:51 PM
Victor's Avatar
Higher tire pressures
A small increase in timing (although I don't think you can do that with a 3.4)
keep the injectors clean
keep it in tune
and most importantly
take it easy while accelerating
Old Feb 11, 2003 | 06:27 PM
L33T35T 4Runner's Avatar
I put high tire preasure in mine... 38 in the front and 40 in the back.. seems to be smoother and better gas milage.
also.. keep the ECT button off... then your shift points will stay lower and use less gas.
Old Feb 17, 2003 | 08:03 AM
Victor's Avatar
So 38 front 40 rear worked for you too?
he's gone
7
Dec 3, 2019 07:08 AM
accuracy
Aug 30, 2015 09:47 PM
raptor510
Aug 19, 2015 02:15 PM
Tacoma1313
Aug 17, 2015 05:44 PM
nonstop
7
Aug 11, 2015 09:26 AM
