leaking cv boots
Old Jun 5, 2005 | 09:10 AM
Rishi's Avatar
leaking cv boots
Anyone knows if the slight leakage in the CV boot and upper a-arm ball joint boot leakage is serious.
2003 4runner, 37k miles
Old Jun 5, 2005 | 09:16 AM
superjoe83's Avatar
i wouldn't worry about it
Old Jun 5, 2005 | 02:20 PM
gman72's Avatar
On a 2003? With 37K mi.? Should be covered under warranty - take it to the stealer for a looksy --- personally I'd demand they fix it (that is, assuming the "leak" coming from your CV boot isn't from puncturing it on a rock or something)
Old Jun 5, 2005 | 06:47 PM
Rishi's Avatar
The CV boots are fine. The grease is bleeding from where it is strapped to the rod.
Old Jun 21, 2005 | 09:54 AM
Godzilla's Avatar
if the grease is bleeding at the rod and there are no tears what is the best solution to this? replace the boot and regrease or is this even a big problem?
Old Jun 21, 2005 | 10:42 AM
mt_goat's Avatar
I had a CV boot leak while I was under warranty too. It was replaced by the dealer no charge. I guess if you have lifted the front and put the CV at an extreme angle they could refuse to cover it under warranty if they wanted to, so be nice and polite if that's the case.
Old Jun 21, 2005 | 11:01 AM
Good Times's Avatar
is the front up on jack stands or something? cuz that cv angle doesn't look healthy for a 4th gen.
otherwise everything looks normal to me.
wafoogalla
Nov 2, 2016 11:02 AM
BeMiceElf
Oct 10, 2015 09:40 PM
ia02
Aug 20, 2015 11:04 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
