Key stuck will not go past acc problem solved.
Old Mar 31, 2005 | 07:48 AM
knockerjoe's Avatar
Update to a post I made recently: Found a bad shift positon switch, toyota part# 33805-35020. what happened was when the shifter goes to park it hits a plastic stop. This was out of adjustment and as a result damaged the shift position switch. To fix you must shim the stop and replace switch. I hope this helps someone in the future. Note this was on a 98 4runner v6 sr5.
Old Mar 31, 2005 | 09:46 AM
PirateFins's Avatar
Good to here you got the problem fixed.
A suggestion, you should post this info in your original post. This helps consolidate the threads and will aid in future searches. If you do move it delete this one at your discretion.
Old Jun 13, 2005 | 11:01 AM
ugadawg95's Avatar
I have the same problem. Just started last week. How did you shim the stop? Was the switch replacement straight forward? Thanks!!!!
gary4runner
Sep 24, 2015 12:53 AM
Odin
Jul 15, 2015 09:28 PM
icentropy
Jul 14, 2015 10:23 AM
Poncho0206
Jul 10, 2015 06:21 PM
colinmil
Jul 6, 2015 04:03 PM
