Old Mar 30, 2016, 11:07 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Lighting Guides
Print Wikipost
How do you remove grill to change headlights?
Old May 29, 2005 | 02:00 PM
92yota4x4's Avatar
I got a 92 toyota pickup and I want to change the headlights. My problem is I don't see a way to remove the grill without braking it. Has anybody done this and is there an easier way to do this? I just really don't want to brake the grill. Thanks in advance for any help.
Old May 29, 2005 | 02:20 PM
Glenn's Avatar
You do not need to remove the grill to change the headlights. At least I never have. Just take a couple of screws out of that metal trim piece and bend it out of the way. The headlight will come out easily. Don't take all four screws out because they are tiny and hard to hold onto (unless you have a magnetic screwdriver). This has always worked for me.
Old May 29, 2005 | 02:38 PM
doink's Avatar
if its like the same year 4runner, you can access the bulbs from behind if you move around some things..
Old May 31, 2005 | 07:19 AM
mt_goat's Avatar
Getting the grill off can be done without breaking it but you will likely need to replace a few of the clips as they are brittle with age. I found on my 93 pickup that there was a way to replace the headlights without removing the grill. There are 4 screws that hold in the headlights. 3 screws can be removed easyly without removing the grill, the other can be removed by drilling a small hole in the grill just big enough for your screw driver. Here's a pic: http://community.webshots.com/photo/...57775808qAjJpg The headlights can then be pulling out from the front very easyly.
Old May 31, 2005 | 11:16 PM
92yota4x4's Avatar
Thanks for the help.
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
HRDC0R19
Jul 5, 2015 06:43 PM
