Help with CODES
Old May 7, 2005 | 12:32 PM
filter's Avatar
Help with CODES
Reporting the following codes OBDII : 99 4runner
P0171 - System too Lean Bank 1
P1131 - A/F Sensor circuit response Bank Sensor 1
Are these codes pointing to a faulty Mass air flow sensor?
Any help or experience with these is appreciated
Thanks
FiLter
Old May 7, 2005 | 12:44 PM
MTL_4runner's Avatar
Thanks
FiLter
Most likely it is your MAF which needs cleaning (usually throws P0171, but can throw others at the same time). In rare cases it may be something else (or could be a MAF which is faulty and can't be fixed by cleaning).
Old May 7, 2005 | 12:52 PM
filter's Avatar
Thanks
How do you clean it?
Old May 7, 2005 | 02:01 PM
dragr1's Avatar
That first code is most likely the maf, I tried cleaning mine, but eventually had to replace it-I got one from a junkyard.
Old May 8, 2005 | 12:49 AM
Tacoma Dude's Avatar
I took my airbox out and sprayed the MAF liberally with electrical contact cleaner.
I saw that there was still some stuff on it and ever so gently brushed against it with a q-tip.
I wouldn't suggest you do the q-tip though...
Old May 28, 2005 | 11:34 AM
filter's Avatar
I tried cleaning the AFM and that seemed to be OK until I eventually seen the light again so I replaced the AMF with a new one.
Now the light is on again with a new code:
P1133 - A/F Sensor Circuit Response (Bank 1 Sensor 1) (Toyota)
Any help or expirience is appritiated
Thanks
Old May 28, 2005 | 12:11 PM
Bob_98SR5's Avatar
filter,
google "OBDII codes"
bob
Old May 28, 2005 | 12:59 PM
filter's Avatar
what do you mean?
I use google for plenty of research.
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
