flashing o/d light and no speedo
Old 04-28-2005, 12:44 PM
91 4Runner's Avatar
Yesterday the o/d light started flashing and I didn't notice it at first, but I also have no speedo. I checked my codes and get code 21 - OK, but the O/D light gives a code 24....What could this be?
91 4Runner is offline
Old 04-28-2005, 02:05 PM
Marc's Avatar
I don't have a reference to a code 24.
To check the transmission short TE1 and E1.
Overdrive switch must be on.
Marc is offline
Old 04-29-2005, 02:28 AM
91 4Runner's Avatar
So yesterday I reset the ECU and no more codes and no more flashing O/D (after about a 10 min drive), BUT I still have no speedo! Help!
Old 04-29-2005, 08:59 AM
Doc279's Avatar
The code will come back - last fall my speedo quit working ( bad cable )
and the O/D light would flash - no running problems though.
I had to order the cable from Toyota $90.00 but it comes with all the clips
and a new floorboard plate. Once I replaced the cable - everything went back to normal. Cable was twisted into inside the housing just below the driver side floorboard. Advance auto parts shows the cable and it looks good - the end for the speedo cluster is wrong ( not big enough )
It would have saved me $50.00 though.
With the cable from Toyota - took me about an hour to replace it.
Doc279 is offline
Old 04-29-2005, 03:50 PM
91 4Runner's Avatar
So I guess it's safe to drive for the time being the way it is? And yes the O/D light started flashing again....
Old 05-02-2005, 04:08 AM
Doc279's Avatar
I drove mine like that for a month or so before fixing it - no problems.
I had to drive out to Oklahoma so I fixed it for the Interstate driving.
Unless you are just being stupid - you will not get a speeding ticket in a 4 runner.
Doc279 is offline
Old 05-05-2005, 02:30 AM
91 4Runner's Avatar
Thanks Doc, I'll be fixing it in another week....
Liadrin
04-25-2022 02:54 PM
Dieselmann
02-19-2019 02:57 AM
AkitaDog
09-01-2015 08:05 AM
Liadrin
09-01-2015 06:44 AM
94ofCanada
08-14-2015 06:37 AM
Quick Reply: flashing o/d light and no speedo
