cleaning MAF
Old Apr 7, 2004 | 10:19 PM
3.4v6's Avatar
cleaning MAF
i just need to get this straight. to clean the MAF just pull it out and spray it down with electrical cleaner? is this right? i searched but couldnt find exact answers. thanks
Old Apr 7, 2004 | 10:25 PM
superjoe83's Avatar
that should work, ive done it to mine a few times, but i used brake clean, because it leaves no residue
Old Apr 8, 2004 | 03:21 AM
ElwayLite's Avatar
Contact cleaner works well because it dries fast and leaves no residue also.
Old Apr 12, 2004 | 08:12 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Contact cleaner will do the job.
Old Apr 12, 2004 | 01:14 PM
JSharp's Avatar
Contact cleaner works fine, but make sure it's a type that's safe for use on plastics. You may need to wipe the wire with aq-tip to get it 100% clean. Be careful...
Old Apr 12, 2004 | 02:30 PM
Mohamed's Avatar
Either that contact cleaner or "A" q-tip with alcohol on the tip.
Old Apr 13, 2004 | 08:02 PM
JSharp's Avatar
Aq-tip? Yep, that's the one.
Posting at work, where proof reading is optional...
Old Apr 16, 2004 | 01:55 PM
3.4v6's Avatar
ok guys , and gals... i sprayed down my MAF with contact cleaner because my taco would stall every now and then but it still stalls, any ideas?
Old Apr 19, 2004 | 10:27 AM
boogyman's Avatar
Talking
dirty spark plugs? plug wires? time for an oil change? dirty air filter? clogged fuel filter? ...any one of those could cause random stalls.. if you do it yourself, should be around $70 to replace all that..
-Russell
Old Apr 19, 2004 | 11:00 AM
NX Tacoma's Avatar
Does it idle rough, that happened once and it was the IAC (idle air control)valve.
Just an idea!
Old Apr 19, 2004 | 11:06 AM
rimpainter.com's Avatar
How is your ISR mod hooked up? Have you oiled your K&N recently? (yuck! )
Did you make any changes just before your stalling problem began?
Old Apr 20, 2004 | 10:31 AM
grafix43's Avatar
-Russell
eh 70$ for all of that? last time i checked factory plug wires are in the 55$ range, a fuel filter is about 37$, oil change 15$, your already over 100$
Old Apr 20, 2004 | 02:55 PM
boogyman's Avatar
Talking
i didn't have wires in there.. and I bought a fram fuel filter (i think they're just as good as toyota) for $20.
-Russell
Old Apr 20, 2004 | 08:21 PM
grafix43's Avatar
-Russell
oh ok cool
smthwsn357
May 1, 2024 07:28 AM
mussy01
Dec 13, 2016 08:20 PM
TACOJO
Nov 27, 2015 05:26 PM
Stull
Aug 28, 2015 05:53 AM
Koolbananass
Aug 12, 2015 01:59 AM
