cleaning fuel pressure regulator
Old Jun 12, 2005 | 06:44 AM
sandcrawler's Avatar
anyone ever cleaned their fuel pressure regulator? (3vze)
mine is ticking like mad and, though it seems to be working ok (no problems to report), i am going to be doing a tuneup (plugs, wires, cap, rotor, clean throttle body, etc.) and thought i might try to clean it to mitigate/eliminate the noise.
i was thinking to just remove it and soak the inside with the carb/throttle cleaner and reinstall it...
if anyone has ever done this, or has an alternative approach, i'd appreciate the feedback.
Old Jun 12, 2005 | 03:34 PM
bump...
Old Jun 12, 2005 | 05:05 PM
DudeBud's Avatar
never heard of the reg making clicking nosies you sure its not an injector of a nosiey valve
Old Jun 12, 2005 | 08:33 PM
Bigblock's Avatar
injector/carb cleaner will ruin the diaphram inside it.
Old Jun 13, 2005 | 04:23 AM
pretty sure it's the FPR; if you lay your hand on it while it's running you can feel it.
3yotys; glad i asked! any alternative suggestions?
Old Jun 13, 2005 | 08:09 AM
Slowrunner's Avatar
yes ,I think thats the part on my truck that ticking. Everyone says I only have noisy injectors but I,m sure most of the noise is coming from that little part. When I put my finger on it I can feel the ticking also.I read a post awhile back and most people here said it was normal and to leave it. Maybe other people here can help with ideas.
jbv808
Aug 6, 2021 04:47 PM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
v_man
Jul 23, 2015 04:01 PM
hamburg99
Jul 13, 2015 09:54 PM
