cleaning the engine
Old Apr 3, 2003 | 07:36 PM
calrockx's Avatar
cleaning the engine
hey i want to clean my engine with that CD-2 stuff, but since i know jack squat about engines i need to know exactly which parts, and where, and how, i need to cover. any other tips would be appreciated too.
here's a picture of my engine, maybe someone could draw dummy arrows and circles in assisting me.
Old Apr 3, 2003 | 07:55 PM
Mohamed's Avatar
You know I need to do the same to my Tundra. When I cleaned my mom's Camry a few months back, all I did was cover the distributor, but pretty much I avoided any direct shots or water around the alternator.
Corey, you'da man for this, for my Tundra and his 4Runner, we have distrubtless ignitions so we probably would want to avoid the individual coils, and probably only cover up the alternator, right Corey?
Old Apr 3, 2003 | 08:45 PM
BT17R's Avatar
I just did this to mine today. There must've been 10 lbs of sand on top of everything from my beach trip this past week. I used a long handled garden shower sprayer that drenches areas with low pressure water with the engine off. Worked great, fired right up, made a squealing sound for about a second and that was it. I let it idle, hood closed, for five minutes then shutdown and residual engine heat dried everything without staining.
Old Apr 4, 2003 | 08:31 AM
Corey's Avatar
Co-Founder/Administrator
To be honest with you, in all my years of washing engines I have never covered anything up.
The only thing I use is Gunk Engine Foamy Brite, and it does a decent job.
I have to do mine most of the time after a run upto the mountains if the roads are dusty and not wet after a rain.
I never spray a warm motor, I do it stone cold.
I let the Gunk sit for about 5 minutes, rinse & repeat.
Then I rinse it with the garden hose, I do it with a light stream and not hard.
And yes I do spray the alternator and the distributor also to get the Gunk cleaner off.
As stated, I never cover anything, but do this at your own risk.
If you feel safer to cover it, you can use foil or Saran Wrap and cover the parts up well.
After rinsing the engine, remove the covers if you used them, then start your engine and let it run fro about 10 minutes to heat up and evaporate the cleaner.
My interior always smells like Gunk for a few days, but the smell dissipates after a bit.
A dirty picture
15 minutes later with Gunk Foamy Brite
Notice the winches big red wires came pretty clean too.
Old Apr 4, 2003 | 10:13 AM
Robinhood150's Avatar
Cover up your cruise control. After I washed mine, my cruise went out for a week or two until it dried.
Old Apr 4, 2003 | 02:36 PM
CLin9383's Avatar
no dummy arrows?? hehe =)
i think that would be the easiest way!!
Old Apr 5, 2003 | 03:58 PM
ABTOMAT's Avatar
I wash under the hood just like the rest of the truck but I do not use high pressure water and never had any problems .
Old Jul 12, 2003 | 06:50 PM
Beartracker's Avatar
washing the engine
For years i have washed the engines of my vehicals with the preasure washer just like the rest of the trucks. Never had a problem from doing it yet. My Tacoma engine gets full of dirt and mud when i go off road so when i stop to wash it i just pop the hood and soap it down and spray it off. My engine looks like the day i bought it. Mike
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
razorman8669
Jul 12, 2015 12:13 PM
