Old Apr 19, 2016, 03:29 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Fuel System Guides
Print Wikipost
Change your fuel filter... NOW
Old Jul 3, 2004 | 08:06 AM
4RUNR's Avatar
Guest
Begin by opening your gas cap to depressurize your fuel line.
Bob, I'm not understanding this. Isn't the pressure after the pump?
Taking out the pump fuse and starting the engine is the only way to depressurize the fuel lines as far as I know.
Old Jul 3, 2004 | 12:42 PM
88yotaboy's Avatar
This is prolly a stupid question but where is the fuel filter located on an 88 pickup?
Old Jul 3, 2004 | 03:00 PM
L33T35T 4Runner's Avatar
any second gen writeups out there? i'll probably do this when i get back from my deployment
Old Jul 3, 2004 | 03:05 PM
Bob_98SR5's Avatar
4Runr,
Yes, you're right. Maybe I should write "partially depressurize"? What do you think?
As far as what you recommended, i dont think that's entirely necesary but I'll add it to the write up. Regardless, a fair amount of fuel will be in there anyways.
Bob
Old Jul 3, 2004 | 05:25 PM
  #25
4RUNR's Avatar
Guest
Yah totally unnecessary, I think pumps on the 3rg gen 'leak' anyway. The logic behind it is the 'hard' starting; which is remedied by turning key to ACC for a few seconds to energize the fuel pump and build up the pressure.
And I did notice that 'hard' starting is present only after sitting for 3+ hours, otherwise it starts up fine, which I guess supports the hypothesis
Old Jul 4, 2004 | 12:18 PM
  #26
LevZeppelin's Avatar
on my 86 the fuel filter is right above the passenger side wheel. there was a little metal plate that i unbolted from the wheel well to make it easier. it would be even easier if you took off the wheel now that i think about it.
Old Jul 4, 2004 | 12:21 PM
  #27
Maddog's Avatar
Pressure is in the fuel line, not the tank. Releasing pressure somewhere else would be more beneficial to the success of the project
All i did with mine was release the pressure from the tank ...by undoing the cap.
I only had about 200-300 ml of fuel come out.& the was very litte pressure.
Old Jul 4, 2004 | 11:32 PM
  #28
calamaridog's Avatar
Originally Posted by Nic
Yeah, the fuel filter is a little tough to get to on the 2.7L. It is under the intake manifold on the driver's side. You have to take the wheel off and get to it that way.
My truck had about 120K miles on it when I changed it, and it definitely needed it. I don't think the previous owner had ever done it. I cut it in half to see how bad it was:
http://community.webshots.com/photo/...18292209CbHfPR
Can you cut a new one in half for comparison sake?
Old Jul 5, 2004 | 04:37 AM
  #29
keisur's Avatar
Originally Posted by Bob_98SR5
guys,
i wrote a write up that explains the procedure: http://www.4runners.org/articles/fuelfilter
bob
Nice writeup as usual Bob. I just have one thing, I don't think those are banjo fittings, they're compression fittings. the 4cyl on my wife's old '99 Tacoma had banjo's.
Old Jul 5, 2004 | 05:19 PM
  #30
Nic's Avatar
Nic
Heh, I would have, but I didn't want to get that scientific.
Old Jul 5, 2004 | 06:14 PM
  #31
Bob_98SR5's Avatar
keisur,
thanks for the correction. will correct in write up.
bob
Old Aug 22, 2004 | 09:26 PM
  #32
Foo Fighter's Avatar
thanks i'll be wrenching on this as well (47k) on my taco V6 does anyone know if it's in the general location as the 4runner?
I'm on a quest to figure out why my taco gets ˟˟˟˟ty gas mileage compared to others avg 17mpg. I cleaned the MAF sensor today so next fuel filter
Old Aug 22, 2004 | 10:57 PM
  #33
wimpywade94's Avatar
yeah, my truck gets horrid gas mileage, partly cause of the crappy k&n filter that clogs WAY to easy, and probably cause ive never cleaned the maf and never changed the fuel filter, or the spark plugs, or nothing.
wade
Old Aug 23, 2004 | 12:08 PM
  #34
CynicX's Avatar
Originally Posted by roger
Your stealership is full of ˟˟˟˟˟. It is a maintenance item (I'm looking at the maint. schedule as I type this) and it should be done every 60k miles, if not every 30k. Of course, my dealer charges $85, which is a ripoff considering you can get the part for about $30 and it takes less than half an hour to install.
/Doesn't go to stealership anymore....
its not in my maintance guide and i didnt see it on toyota.com's maintance schedule for the 3.4 v6.....
Dont get me wrong, I'm not saying its not a good idea to do, because it is......but some vehicles dont have servicible fuel filters, take jeep wranglers for example, the fuel filter is located inside of the fuel tank at the pump....to change it would require you dropping the tank....saying "it unscrews, so that means its a maintance item" doesnt really make sense, because I cant think of one think on the vehicle that doesnt unscrew, unbolt or unsnap....
I dunno why I'm arguing against you guys since I do agree with changing it...heheheh
Old Aug 24, 2004 | 06:53 AM
  #35
Ak4runner99's Avatar
Newby here. '99 4Runner V6 SR5
I tried to replace my fuel filter last night, and could not get the compression fittings on the 'Out' side of the filter to reseal. Spent a couple hours taking it off and putting it back on, but it continued to Leak at about 1 drop every 3 seconds.
I ended up putting the old one back on and No Problems.
I did notice the inlet and outlet holes on the new filter are noticably bigger than the old one (probably about a milimeter). Could this have caused the leak? Did I get a bad part (Toyota Fuel Filter #23300-62030 )?
Old Aug 24, 2004 | 07:48 AM
  #36
roger's Avatar
That's weird...the maintenance schedule I got from the dealer specifically lists the fuel filter...maybe they changed it since then.
At any rate you're correct, it is worth changing since it's so easy and cheap to do.
Old Aug 27, 2004 | 10:12 PM
  #37
i crawled under my 02 dbl cab taco recently and it's in the same location as the 4runner mentioned...under the driver side looks pretty easy to do...you guys think 42k is too soon to change it out?
Old Aug 28, 2004 | 12:23 AM
  #38
Tacoma Dude's Avatar
I'd think so.
I'm at 64K and I'm going to wait until 100K
Old Aug 28, 2004 | 11:42 AM
  #39
humanoid's Avatar
Yeah, I agree with Tacoma Dude, wait until 100K to do it. With only 42K there's not much crap in the filter yet.
Old Aug 30, 2004 | 12:34 PM
  #40
payyourtoll's Avatar
this cracked me up - GREAT post
