Blown Rear Oil Seal...??
Old Mar 22, 2003 | 06:48 AM
data's Avatar
Senior Member
I think I might have a blown rear oil seal. But also there is a noticable "clunk" sound when I drive it at low speeds. How hard is that seal to replace? Here's a photo..
Old Mar 22, 2003 | 03:48 PM
Shane's Avatar
Re: Blown Rear Oil Seal...??
PITA
I've had one leaking for months now, waiting for some stuff to arrive so I can swap in my e-locker modified axle. There's two seals (inner & outer), the bearing, and the retaining collar that you'll need. You'll also most likely need a press to get the bearing off so you can replace the seal. Can't say what your clunk sound is, but the bearing could be toast in turn destroying the seal.
Old Mar 28, 2003 | 03:25 PM
Adam F's Avatar
Clunk sound is your brakes catching and letting go because of the oil in the drums
bigjstang
Jun 2, 2025 03:56 PM
sandyota
Feb 4, 2021 11:16 AM
87blyota
Jul 10, 2015 04:31 AM
icentropy
Jul 9, 2015 02:12 PM
toyoda8488
Jul 5, 2015 10:18 PM
