Ball Joint Bad?
Old Jan 23, 2004 | 10:00 AM
Denk's Avatar
Ball Joint Bad?
Do the boots covering the joints have to be busted or leaking for the joint itself to be bad? Even if the boot were busted, that doesn't mean that the joint would need to be replaced, just a new boot with some new grease, right?
Old Jan 23, 2004 | 06:24 PM
AverysDad's Avatar
not neccesarily.........
a ball joint is basically a cup with a ball that fits into it and moves as the suspension goes up and down. if the cup or ball has been worn enough there will be a certain amount of play that can affect the suspension and make it hard to get an alignment.
it might be worth it to take it to a mechanic you trust and have an expert opinion on it..............im sure it wouldnt cost much to have looked at then you'll have some peace of mind.
krimsonone
Sep 13, 2024 09:33 AM
Sep 4, 2015 09:27 AM
gillesdetrail
Aug 3, 2015 04:43 PM
coffey50
Jul 28, 2015 10:55 AM
ksmudrunner99
Jul 21, 2015 05:33 AM
