Auto Guys: Tighten that kickdown cable.
Old Jun 28, 2005 | 02:27 PM
Rivalred's Avatar
I guess I am running a drive by wire system...
Old Jun 28, 2005 | 03:20 PM
dibble9012's Avatar
Originally Posted by Tacoma Dude
You don't want to do this - it'll mess up your tranny pretty quickly.
Dont do what, tighten the kickdown cable, or drive it so the tranny doesnt keep up, I tightened the cable and it seemed to help, everything runs fine
Old Jun 28, 2005 | 03:52 PM
Tacoma Dude's Avatar
If you look at my post I was quoting you from a previous post.
I did that with my parents' Camry and killed the tranny. I did it so much that I could almost "manually" control the transmission. Later on it got to the point where I'd reach a certain speed and the auto tranny would shift between gears constantly because it didn't know what to do.
So... don't do that whole ease off and press down accelerator thing. Bad news.
Old Jun 28, 2005 | 06:47 PM
naksukow's Avatar
You can probably hook up a mechanical pressure gauge to the tranny and measure the stock line pressure, then measure it when the slack is taken up in kickdown cable. Its an old trick to firm up shifting and done with some thought is safe. As long as you don't go overboard you should be fine.
Old Jun 28, 2005 | 10:30 PM
  #25
AgRunner06's Avatar
Yeah mine isn't tightened up much more than tightening the slack in the cable. I'm pretty sure I'll be ok.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
urabus
Nov 10, 2015 07:38 PM
Corvoid
Sep 14, 2015 10:10 AM
May-39
Sep 6, 2015 01:05 PM
