Antenna Lubing...
Old Dec 7, 2002 | 07:29 PM
BTOWN4RUNNER's Avatar
Antenna Lubing...
I know this has probably been discussed, but I am going to ask again. I want to lube up my antenna, so that it does not break again. I want to just lube up the metal part that is exposed (the actual antenna part). I was thinking about using Silicone spray. Does this stuff freeze. It is really cold here now and I don't want it freezing on me. That is why I don't want to use WD-40. Any one have any other ideas or can help. Thanks. :fireman:
Old Dec 7, 2002 | 07:37 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Just keep it clean. Moisten a rag with lighter fluid or kerosene and clean any dirt off of the mast. Wipe the mast dry. No lubrication is necessary. If you feel you must, moisten another rag w/WD40 or any other silicone liberally. Any gunk that gets inside may cause premature failure.
Old Dec 7, 2002 | 08:22 PM
Corey's Avatar
Co-Founder/Administrator
I read the same thing a few days ago on another forum.
If you lube your antenna, it will fail.
It's best to just wipe it down.
I have never lubed mine, and it works great.
Plus it goes up & down several times a day whenever my door opens.
The antenna goes up as part of my alarm pager system, so it gets a healty workout.
Old Dec 8, 2002 | 07:14 AM
Alright, cool, thanks guys. I will just clean the antenna really good and that is it. I was not sure if doing something would hurt or help, but now I know. Thanks! :fireman:
Old Dec 9, 2002 | 03:28 AM
wayne's runner's Avatar
I use electrical contact cleaner on mine
It takes off all the crud and leaves it nice & clean. Don't apply any type of oil, it will only attract dirt and bind up in really cold weather (it was 5 deg. here in SE Wisconsin today).
zombie_barbarossa
Oct 2, 2015 10:54 PM
tazman1972
11
Sep 28, 2015 10:32 PM
shisha1999
Sep 20, 2015 11:35 AM
Ilovemountains
Sep 15, 2015 04:17 AM
msged2007
Aug 22, 2015 07:46 PM
