22re expertise ASAP!
Old Feb 25, 2003 | 07:08 PM
guitarsncars's Avatar
ok..i got it runnig, loping realll hard....shaking stuff loose hard. Adjusting any further than 10* BDC causes the truck to kill, but I havent adjusted the TPS yet..still figuring out just how to do that. BUT! my question is this: i shot a digitemp laser at my headers after 5 min of 'idling' (in the ' ears ' because its almost not even qualified as idling, it so freakin sparatic)
1 cylinder : approx. 495*F
2 cylinder : approx. 250*F
3 cylinder : approx. 500*F
4 cylinder: approx. 180*F
WHY are 2 and 4 much colder than 1 and 3? is this why its cutting out? Could the unkown green connector i have dangling in my intake side have something to do with it? after all, it does fit on the injector plugins. GOD im about ready to drop a match in this things gas tank. someone please help!
Old Feb 27, 2003 | 05:32 PM
*bump* 20 hits and no replies? good lawd! well, update time. turns out theres no spark in 2 and 4. Im about to see if my dist. is bent. hoo...that would suck.
Old Feb 28, 2003 | 06:19 AM
williemon's Avatar
I was gonna say that #2 and #4 must not be fireing as much.
Old Feb 28, 2003 | 06:30 AM
hahaha...thanks! : gonna figure this out today, i can feel it in mah bones!
Old Feb 28, 2003 | 12:21 PM
Shane's Avatar
I'd recheck the injector connectors, you may have them crossed up or that connector you've been wondering about may have something to do with it. If I remember correctly, injectors 1+3 and 2+4 fire together in pairs...
Old Feb 28, 2003 | 03:46 PM
partszar's Avatar
no spark to cyl 2 an 4
All the reluctor in the distributor does is tell the coil when to fire the plug(s). I seem to recall you said you had some type of A/M coilpack set up. Sounds to me like the coil pack that fires cyls 2/4 is not working. Thats my gut feeling. if it is possible to swap coils try that and see if 2&4 now fire and 1&3 quit working. Also I have a FSM for that year if you need any info. I can copy/fax.
Old Feb 28, 2003 | 03:50 PM
well, its an Accell PowerStack (?), yellow ignition coil. So I dont think its able to just fire 1 and 3, 2 and 4....its a continuous spark, no?
Old Feb 28, 2003 | 04:22 PM
partszar's Avatar
on vehickle spark test
Heres something i just found in the FSM.
ON VEHICLE INSECTION
SPARK TEST
NOTE: PERFORME THIS TEST TO CHECK THAT CURRENT IS COMING FROM THE DISTRIBUTOR.
1. Connect timing light to each spark plug (wire)
2. Crank engine and check that light flashes.
If timing light does not flash, check the wiring connections, ign. coil,igniter, distributor or ignition switch.
what they mean is hook up the light and move the end that wraps around the plug wire to each wire in order to check for a spark signal to the plug.
BTW this just occured to me check to make sure the plug wires for cyls 2 & 4 are not crossed on the cap or at the plug. Firing order is 1-3-4-2 that will definately cause it to run on 2 cyls only. HTH
Old Feb 28, 2003 | 04:28 PM
partszar's Avatar
SPARK TEST
nvdesertrunner
May 11, 2020 08:18 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
129Creepin
Aug 5, 2015 10:12 PM
Flossy
Aug 5, 2015 05:14 PM
