1996 CV Halfaxle Issues
Old Jan 19, 2004 | 02:15 PM
Bradass80's Avatar
This past weekend I replaced both left and right side halfaxle assemblies, I used replacements from Checker, the install and removal of the old ones went smoothly other than two things:
1) I lost almost a quart of gear oil when the axles were out and for some bonhead reason I can't seem to find the fill plug for the diff, am I blid or is it just in a weird spot??
2) With the truck in 4wd if i turn right i get a squeek out of the right side, if i turn left i get a squeek out of the left side, WTF???
Any ideas would be really appreciated, i can't see anything rubbing but that is what it sounds like, TIA, Brad.
Old Jan 22, 2004 | 08:45 AM
Darren's Avatar
Hey Brad. Obviously, I got your PM as well but thought I'd bring this up to the top at the same time.
One of the members seems to have a good write-up on chaning the diff fluids. I say seems to as I have yet to do it myself. Anyway, there are pictures on it as well which will hopefully lead you in the right direction. Here's the write-up.
Unfortunately, I can't help on the squeaking issue.
So, you replaced the axle shafts in addition to the boots then? I really need to learn to do this myself should the need arise. And I'm sure it will. So, assuming you didn't take pictures, would you mind re-doing it all and do a thorough write-up on this?!
We'll talk to you later.
Old Jan 22, 2004 | 09:01 AM
Bradass80's Avatar
Darren, I may end up re-doing the repair, squeeks are like oil leaks, I just won't stand for them, Brad
Old Jan 22, 2004 | 09:10 AM
Bradass80's Avatar
Darren, BTW, That write-up was exactly what i needed, Thank You, Brad.
terminator
Jul 27, 2015 07:13 PM
cgilley
Jul 25, 2015 10:55 PM
jgwerth
Jul 16, 2015 03:23 PM
cgilley
Jul 15, 2015 03:32 AM
