1995 3.0 check engine light
Old Apr 3, 2005 | 10:53 AM
yarmish's Avatar
Unhappy 1995 3.0 check engine light
hello,i just bought a 1995 ext cab pick up with 3.0 and it has only 40k on it.but today i was driving it and the check engine light started flashing on and off,and when it did the truck would lose power and hesitate.it would then go off and back on and so on......this all started when i went to start the truck and it took 3 times to get it going...any info on what the problem is would be appreciated..
thanks
Old Apr 3, 2005 | 12:48 PM
yarmish's Avatar
Unhappy
i pulled the code from the diagnostic port and it is a code # 12
which reads in the off road.com tech article
-distributer circuit
-starter signal circuit
-igniter circuit
-ecu
any ideas on what these mean???
please help!!!
Old Apr 3, 2005 | 01:29 PM
91Toyota4x4's Avatar
-igniter circuit
-ecu
please help!!!
Maybe you should check the distributer, igniter, and ECU. If it starts the starter is probably ok.
Old Apr 3, 2005 | 07:18 PM
frankenrunner's Avatar
Guest
i would check the main power leads & grounds to each one;
see whether or not the power steering pump is &/or has leaked before(it can leak down onto the starter & cause ya some serious problems:
i'd also grab the starter & wiggle the distributor to see whether or not they were tight;
you may just end up having to change the distributor, rotor, plugs & wires(a basic tune up).
good luck,
-f-
p.s. welcome to the site & enjoy, it is a cornucopia of info!
sonic concepts
Aug 16, 2025 03:13 PM
Jdgarrison
Oct 1, 2015 05:22 PM
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
94hiluxZE
Jun 22, 2015 10:42 AM
