Engine Swaps Swapping an engine in your Toy, here is where to learn how
swap for gm engine question
Old Oct 15, 2008 | 01:33 PM
sgwan's Avatar
83 toyota pickup. is this all I need to do a swap?
4.6 gm v6
trans. and related parts
axles
computer
wiering harness
could I take those from a gm truck and mount it all on a 83 toyota?
what I am trying to do it turn it into an auto with the gm v6 and also swap axles so its auto locking hubs.
is it possible????????????????
Old Oct 15, 2008 | 07:40 PM
Adam F's Avatar
Its a 4.3L engine not 4.6
Sounds easy, but its a lot more work than that.
You'll also need to buy or fab motor mounts, trans/transfer crossmember, transfer case from GM or an adapter for your Toy case, exhaust, drive shaft work, new radiator, fuel pump, new fuel lines,
Anything is possible with enough time and effort. Or enough money to pay someone else to do all the work.
Old Oct 15, 2008 | 08:46 PM
sgwan's Avatar
even making it an automatic and making it have auto locking hubs? those are my main conserns (I like auto for off road ) and I ment the gm 4.3, or do they make a 4.6?
anyway, those are my main conserns, cuzz if its an manual to start with and then I turn it into an auto, how would I shift it from park? if you dont know thats ok, aslong as its possible to go from manual to auto.
thanks
Old Oct 16, 2008 | 01:08 PM
blackspyder's Avatar
there is a 4.6 V8 out there (but I think its a Ford)
I'd find a 4.3 Carborated Motor if state laws allow you to do so. They run pretty good with minor Cam changes and a 2bbl Holley. (less electronics to deal with, and upgrading to TBI, EFI, or the Vortec is fairly straght foreward if you decide you want too later)
TH700R4, or TH350/400 automatics work well with the 4.3. As for Shifting just use a B&M floor shifter from AZ, AA, Jegs, ect. Easy install.
Old Oct 16, 2008 | 09:54 PM
sgwan's Avatar
sweet! what vehicle would I find the shifter in and the trans. and the engine? also what axle would I use to make it auto locking hubs?
thanks
Old Oct 16, 2008 | 10:04 PM
fillsrunner4's Avatar
Youve got alot to learn before you can do this swap! Time to start researching information cause otherwise youll dig yourself into a hole you cant climb out of
Start here 4.3 FAQ
http://www.pirate4x4.com/forum/showt...chevy+swap+faq
Ive got a 4.3 build thread you can find the link to at the bottom of my sig also
Old Oct 16, 2008 | 10:53 PM
sgwan's Avatar
oh yeah I understand its no easy thing. hehe. but I almost get chills just thinking about doing it all.
here is what I am looking at getting, only at a much cheaper price if I can talk the guy down. just about every thing leaks, but its street legal and his DD, so it does run.
what do yall think the price should be?
http://easttexas.craigslist.org/cto/860196081.html
Old Oct 17, 2008 | 12:56 AM
Adam F's Avatar
I agree. If you dont know the difference between the workings of an auto and manual trans, you shouldnt be doing an engine swap.
ANd the auto hub deal is probably going to be way more trouble than its worth. Maybe use a wagoneer vacuum actuated axle?
Old Oct 17, 2008 | 01:07 PM
Mid-80's S-10 and S-10 Blazer's are where you'll find the Carb 4.3 mated with a Th350 or (maybe) TH700R4. Best to look for the 700R4 in a K1500 more common there and the T-case for a Mid to late 80's isnt the worst.
The Shifter will almost have to come from a Parts store or Catalog (not saying it cant be done but for $100 its not worth the hassle trying to find a good GM floor shifter).
Auto lock hubs are too much trouble to deal with my S-10's had them and they all got converted to "cable pull locking" style.
But I'd leave the Truck as is and fix the leaks. Going 4.3 is going to be a massive headache with a non-stock vehicle
Old Oct 17, 2008 | 09:16 PM
sgwan's Avatar
I know how they work, I was only wondering if its possible to use in auto on a manual truck, but I may end up likeing manual off road anyway.
what I dont know is how axles work. what I mean by auto locking hubs, is swaping axles out so that I dont have to get out and twist the hubbs. would I accomplish this by cable, or vacume? how does it work?
thanks
GreenLion
Jun 7, 2021 10:49 AM
Jun 1, 2021 01:51 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Lowviz
Jul 22, 2002 10:52 PM
