Should I rebuild my engine in my 93 toyota pickup DLX or put a 350 or something else
I have a 1993 Toyota pickup and I'm at a point where I want to either rebuild the engine with upgrades or possibly put a completely different engine in it I'm just not sure what engine I would want in it or what will run Good with it
I have the 3.0 in it right now and I had that engine put in about 2 years ago because I blew the other engine that was in it but the people who put it in lie to me that it was a good engine. For right now the engines running ok but I do have to do some work on it and the work by itself it only cost me about $1,500 and I'm not sure if I should just do that or rebuild the whole engine or put something else into it
I need the knock sensor which is about $800 I have a rear main seal leak with another 300 there's a gas leak on my engine somewhere and there's some wires that are not connected completely and I'm not really sure where they go I have tried to connect everything I could from what I learned at my shop but I'm not too familiar with my Toyota and it's engine
yea i do get a code 52. But its just i feel like i lose power in second gear. I put a lighter to the fuel injector and it lit up a bit. I wanna put headers and do a bit of mods. I would like to put a 350 v6 vortec in it but im just not sure how much all this would cost
The vortec v6 fits pretty good..but again. Lots of $$$ and at the end of the day you have a Chevy.
I would recommend a 3.4 Toyota swap. The engine bolts up to the trans and the engine mounts. A little bit of wiring and your set.
I can tell you that a 350 is possible but it's going to be a whole bunch of work and a lot of $$$$$
The 3.4 swap will need a little exhaust work and some wiring. But for the most part you can buy the plug and play for it. The 3.4 is a mass produced engine by Toyota and can be found anywhere. Junk yard, or online.
As soon as my 3.0 blows I'm going with a 3.4 Toyota supercharged
The 3.4 is the better, stronger and faster version of the 3.0. Like I said. It all bolts up.
It depends on where you are. Here in California it's kind of hard to find a 3.4 in a junk yard. I would recommend finding one used and using it or rebuilding it. Get it dialed in, then supercharge it. You need a bit of a body lift to get the hood to close , but the rest just bolts up to your factory everything. Maybe find one a truck with one being parted of on a craigslist type of site. Buy a parts truck with one. You have a lot of options.
yea, it will need an inch or two of body lift. Suspension lift doesn't help the engine compartment. Compare your body mounts to another truck. Or take a picture of your engine compartment and post it....you can tell by just looking at it.
It looks stock to me. The dead give away is the firewall / coolant hoses hang out like a sore thumb. Look into a fan shroud if you going to be going up hills and towing. The last thing you want to do is over heat that 3.0. Cooler the better.
i have a fan shroud just havent put it on. So my budget is about 3000 and I'm not sure that's enough to get a 3.4 because if it's not I rather just put that money into rebuilding this engine and putting upgrades into it
I am a 3.0 fan. I beat the life out of mine and it's never left me stranded. I'm going to do the 3.4 in my other truck, but have no complaints with my 3.0. As long as you keep it cool you will be fine.
No matter how much money you put into the 3.0......it's going to be slow. They are gutless regardless. The 3.4 has the power you want.
get that shroud on. If I where you I would run the engine you have until it gives up. Save your money and then do the 3.4
80s Rule
44
Jan 5, 2019 10:04 PM
arlindsay1992
Feb 21, 2017 01:11 PM
coolfool
Jan 19, 2017 09:09 PM
93RedKrawler
Jul 17, 2016 09:11 AM
