Engine Swaps Swapping an engine in your Toy, here is where to learn how
6 speed manual swap and t/c??
Old Nov 25, 2007 | 10:48 AM
okidoc's Avatar
If someone wanted to drop in a GM LS1 with a 6 speed manual into a 95 V6 4 runner, how would they go about adapting a t/c to the tranny?
Also is there anyone who has installed a V8 and kept their A/C intact?
NWOR has some great products that look like they may make the swap easier, has anyone used their looms or mount kits?
Old Nov 27, 2007 | 12:29 PM
bigarms23's Avatar
I did the same swap in my bosses 844runner and i had to call advanced adapters and have them make me an adapter
Old Jan 9, 2008 | 09:20 AM
rockdawg84's Avatar
Just use OTT's divorced case adapter. runs about 400 bucks and then run whatever trans you want. just a thought.
Old Mar 4, 2008 | 12:41 PM
zach540's Avatar
I too was considering the same swap, putting a T-56 behind the LT1 in mine and I was told... "the ouput shaft on the T-56 has a problem with oversized tires and will not last with that low of a gear ratio". I can't remember if it was Downey or Advance Adapters that told me that tho, it was probably 6 years ago, just as an FYI. Good luck to you in your swap.
Zach
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
wilbertd
Jul 6, 2015 07:39 AM
HRDC0R19
Jul 5, 2015 06:43 PM
