wolfrunners sas and chev spring swap
Old Oct 18, 2010 | 08:30 AM
  #61
4x4jeffyota's Avatar
man your rig looks great
Old Oct 18, 2010 | 04:49 PM
  #62
RoBatt's Avatar
Originally Posted by blake.nemitz
cause my angle off the t case is like 38 degrees at ride height and if i go too fast ill toast the u joints or rip[ it apart. if i had a hi pinion diff i would knock 10-12 degrees off, ps i dont run a cv even a 85 clearanced one would bund a little im single joint on both ends, 2nd gen runners have a little bit longer finger on the yoke that hold the u joint and can run at an extreme angle without binding compared to first gens which had shorter fingers on the yoke
Im sure this is a pretty obvious question but where to you get a hi pinion diff? what do they come off of?
Old Oct 19, 2010 | 04:17 AM
  #63
blake.nemitz's Avatar
80 series land cruisers i think, trail gear sells the hi pinion housing and you can swap over a carrier and im not sure about the gears but you would probably want to get new ones with a hypoid cut instead of standard, i could be wrong someone will correct me im sure
Old Jun 8, 2011 | 10:26 PM
  #64
corystephen79's Avatar
Very nice buildup!
Old Jan 9, 2012 | 07:24 AM
  #65
MaK92-4RnR's Avatar
whats the specs on this build? I know you have some of it in your sig but what front springs did you use? also, how does she ride?
Old Jan 11, 2012 | 11:53 AM
  #66
superswamper003's Avatar
That is one sexy 4runner haha. Have you made the rear level with the front yet?
Old Jan 22, 2012 | 01:44 PM
  #67
MP's4R's Avatar
plus i have been trying to figure out why my runner leans to the right by about 3".
You may have dearched the spring by over flexing it without bumpstops.pretty sure i did the same thing testing mine out. i dont know much about springs but i think anything past flat/ negative arch is not good for them. Try flexing it the same way rom the drivers rear tire. Mine leaned to the passenger side which corresponse to how i flexed it. I bet its your fronts not rears. Also when i installed my hysteer i didnt have the drag link ajdusted poperly with how the pitman was aligned and on left turns it would actually tug down on the front driver side. Just a couple things to think about that i ran into.
Flying91
45
Apr 11, 2024 04:39 PM
Backcountry411
Jul 24, 2015 08:06 AM
boogiewoogie
Jul 24, 2015 05:10 AM
yourrealdad
Jul 21, 2015 11:13 AM
