what springs do i run for sas swap with a v8 motor??
Old Aug 24, 2010 | 06:19 PM
Jake Adams's Avatar
im doing a 302 swap in my 87 toyota but straight axle swap as well. i heard from some people to run the tg 5'' hd springs in front. is there anything better than this or what should i use? i'm wanting to run 38's for tire size
Old Aug 24, 2010 | 06:24 PM
2DoorRunner's Avatar
5" HDs should be exactly what you need.
Old Aug 24, 2010 | 06:34 PM
Jake Adams's Avatar
ok thanks! with the 302 swap, i got a np435 tans. do i need to run a body lift to clear that trans. or will it be fine?
Old Aug 24, 2010 | 06:41 PM
You dont NEED anything. But Advance adapters claims that a 2 inch body lift is manditory for firewall clearence.
That can always be solved by running the whole drivetrain lower, or modifying the firewall.
Since your doing a SAS you can weld in motor mounts and place the motor and trans almost anywhere you want.
My buddy stuffed a TBI 4.3 Vortec under the hood of his 85 4runner. He didnt have to modify any sheetmetal.
Old Aug 24, 2010 | 07:01 PM
Green_slime's Avatar
you dont need a body lift but it does make life alot easier but beings that your distrib is in the front unlike mine you are better off i have a 3 inch body lift on mine and everything fits just fine
Old Aug 25, 2010 | 06:22 AM
Jake Adams's Avatar
ok thanks. i just got my hands on a 85 front axle for the truck, and it has 529's with a detriot lokcer. the guy who had it ran dirty 30's but since im puttin the 302 in it would those axles hold up fine or should i put the longfields in it
Old Aug 25, 2010 | 12:37 PM
What size tire will you be running?
Street or trail rig?
Im only asking because people will run huge tires without regearing after a v8 swap, so you might be overgeared, but thats not always a bad thing
Sorry i dont know crap about birfs.
Old Aug 25, 2010 | 12:39 PM
blake.nemitz's Avatar
i heard dirty thirtys are good, my buddy runs them but with a 22re and 40's good luck on your build man looking forward to seeing some pics
Old Aug 25, 2010 | 06:25 PM
Jake Adams's Avatar
thanks for the info! im just trying to get some more output to deside whats best. does anyone have or know anyone with hi steer for sale
Old Aug 26, 2010 | 04:23 PM
Silver GT's Avatar
I had a 94 pickup with a chevy 305 TBI, 700r4, np208, SAS with TG 5"HD springs, 5150s all around, 3" body and 36" TSLs. It was nose heavy and the front springs still felt really soft. When i hit the brakes for a stop sighn or what ever it would hit the bump stops. I welded the front hanger flush and my shackle angle was too much, it hit the body mount. I would def weld the hanger farther forward. Im not sure the weight differance between ford and chevy small blocks either tho. Hope this helps.
Old Aug 26, 2010 | 08:35 PM
its been 2 years since i did my conversion and i have stock transfer and alxles they have held up just fine with 33s i and i have put them through some pretty nasty stuff
Old Aug 26, 2010 | 09:40 PM
Jake Adams's Avatar
ok thanks. ya im plannin on gettin the tg 5'' springs and probably a 2 in body lift. but im gonna put at least 36's under it. im hopin to put 37's or 38's boggers. but the inner axles are still stock. so just gotta get some dirty 30's or the longfields. ill take pictures once i get everything and start the build up
Old Aug 26, 2010 | 11:44 PM
Sounds good man, cant wait to see how it turns out.
ladybugRC
458
Aug 21, 2020 10:41 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
dirk89
Oct 1, 2015 05:15 PM
whiteyota93
Sep 29, 2015 02:31 PM
Toys4parts
Sep 26, 2015 01:56 PM
