Trail Gear 4" front sas kit, 4" rear
Old May 31, 2010 | 09:56 AM
91_TOYOTA_4x4's Avatar
what a beast ^^^ love the stance
Old Jun 1, 2010 | 08:10 AM
skunkwhat's Avatar
thanks man.
Old Jun 3, 2010 | 11:50 PM
frm_808's Avatar
i see a pop vented hood
Old Jun 4, 2010 | 08:37 AM
skunkwhat's Avatar
yeah, gotta clear the 3.4 intake. I didn't want to body lift it, or put a hood scoop on it.
Old Jun 4, 2010 | 10:33 AM
  #25
frm_808's Avatar
i see wat you mean..i dislike both
Old Jun 5, 2010 | 04:16 PM
  #26
86bedlesstoy's Avatar
Nice job!
  #27
Where did you get the shock mounts?
Old Jun 6, 2010 | 07:32 AM
  #28
skunkwhat's Avatar
I assume your talking about the front shock mounts? They are, off the shelf trail gear shock hoops.
Old Jun 6, 2010 | 07:59 AM
  #29
RiCh_90-yota's Avatar
great work
Old Sep 17, 2010 | 11:40 AM
  #30
stock as possible's Avatar
What size shackles did you end up with front and rear? Did you french any of the hangers?
Old Sep 30, 2010 | 10:40 PM
  #31
VANCE164's Avatar
Paul Where's some wheeling pics I know you have to be doing something out their in idaho other then working
Old Oct 18, 2010 | 03:16 PM
  #32
RMP8080's Avatar
nice work.good luck
Old Oct 19, 2010 | 04:21 AM
  #33
blake.nemitz's Avatar
a 3rd gen taco or 4runner scoop grafted in would look pretty sharp but nothing else
Old Nov 9, 2011 | 08:41 AM
  #34
Bawlzdeep's Avatar
X2 on the wheeling pics! Looks good, nice work
Old Nov 21, 2011 | 05:37 PM
  #35
Dixyboy69's Avatar
Looks great man! Im actually planning on doing the same swap onmy truck. Funny things is I have the exact same truck even down to the color, so seeing yours has given me the itch cuz I know exactly how it should look! Thanks for the updates. Ill be sure to get in touch with you when I get to mine and have some questions.
Old Nov 22, 2011 | 09:59 AM
  #36
skunkwhat's Avatar
Ok, so I have been slacking on updates, and more importantly pics. The front end is basically "built" now. Longfields, marlin 25mm knuckle bearing kit/ high steer arms, tg knuckle ball gussets, tg full face diff guard, flushed in front drain plug. The truck has a warm m8000, and a bumperr I built using a tg winch plate and some 1.75 tube. I also have all the parts to do duals, and a 4.7 gear set, picked up a front range x member too. pics soon....I almost forgot, I'm now running the tg 4" hd springs. The regulars were bottoming out on the bump stops as I would just drive down the road. It is a little bit higher, as the new pics will show, but doesn't bottom out anymore, the front end is pretty hefty with a 3.4, and a winch on the front too.
Old Nov 22, 2011 | 10:08 AM
  #37
Ravencraft's Avatar
Good looking build! Looks almost EXACTLY the same as the SAS I just did to my p/u. Same kit, same tires, same gears, same lockers (mine's got a detroit front and yukon rear) hell, even the same black front passenger fender! I'd post a link to the thread... but I'm lazy. If only I had that 3.4... My 3.slow isn't long for the world at this point.
Great job. As much help as the plasma cutter was, looking back I'd have killed for a torch when doing the frame tubes!
Old Nov 22, 2011 | 10:13 AM
  #38
skunkwhat's Avatar
lol, man I love this 3.4, it just costs way more when doing dual cases, but this thing runs like a champ.
I def. think that plasma and the torch each have their own strenghts.
Another thing I forgot, I put in the tg, magnum arp's, and the front range hub studs.
Old Nov 23, 2011 | 12:11 PM
  #39
tlrskunk's Avatar
Those 35's look tiny on your truck. you need 37's I have to go bigger on my Runner when I go to tons.
Old Nov 23, 2011 | 12:23 PM
  #40
MaK92-4RnR's Avatar
I think it looks good either way. I think the 3" kit is a little better for 35s though. gorgeous truck!
