Starting the process of the SAS...
Old Jul 24, 2007 | 12:23 PM
  #61
chimmike's Avatar
Originally Posted by 4Runner92sr5
hahaha yeah that thing is heavier then crap with everything on it hahaha the hanger and holes should be cut by the end of this week im hoping to do the SAS on monday or sometime next week.
Cool deal man. The cutting takes the longest, IMO. The grinding wasn't that bad. I just made sure everything got a good coat of primer before I sprayed with enamel. Of course I'll have to wire wheel off some parts to weld the shock hoops on, but eh, whatcha gonna do?
Keep up with the pics
Old Jul 24, 2007 | 04:05 PM
  #62
4Runner92sr5's Avatar
done for the evening
well i got both knuckles on and ready to go and the shock hoops painted most of the way except for the part that is going to be welded. spent the rest of the time admiring how crappy it looked when i picked her up and how good she looks now hahaha
Old Jul 24, 2007 | 04:48 PM
  #63
chimmike's Avatar
I'm at the same point you are in the pics, except my spring perch is welded on. I got the hubs all greased for the bearings, but my dumb ass threw out the washers and hub nuts, so I had to order some overnight
Old Jul 24, 2007 | 05:15 PM
  #64
its all good man yeah i gotta go and buy a 3lb sledge cuz a nail hammer can't cut it anymore the new wheel studs need some force then ill get the bearings and the rest of it together i figure i misewell take my time since i have it for now...
amazing how bad it can look and how purty we can make em
Old Jul 24, 2007 | 05:37 PM
  #65
chimmike's Avatar
yeah you'll need a 3lb sledge AT LEAST....definitely need a brass drift, some center punches, etc.
Get a big breaker bar for the disassembly of the upper a-arm and torsion bar.
BTW....loosen the torsion bar as much as you can, then un bolt it from the a-arm. Then, disconnect the upper arm from the ball joint, and remove the 3 bolts holding the a-arm in place. You should be able to slide it off the torsion bar and remove it. Then the end thing that bolts to the arm on the torsion bar comes off, so you can slide that thing out.
As for the lower crap, just CUT IT, lol. Saves a TON of time. Make sure you're either cutting the diff mounts or unbolting the diff from all that first. Even using the Sawzall, I went through like 4 cutting wheels and 3 grinding wheels. And I used the Sawzall extensively.
Old Jul 24, 2007 | 06:01 PM
  #66
hopefully me and jeremy can rent a plasma cutter cuz thats what he used and he said it took like 15 min to cut everything out but if not i still get to take my frustration out on my IFS by cutting the crap out of it hahahah
Old Jul 24, 2007 | 06:12 PM
  #67
44Runner's Avatar
Plasma or a torch is the way to go. Don't bother unbolting anything you aren't keeping, its a waste of time. You should be able to make short work of the tear down. The grinding takes a little while though. Then start throwing everything on...
Old Jul 24, 2007 | 06:16 PM
  #68
heck yeah man im excited i just have to see when this guy can weld my hanger and cut the holes hopefully the end of this week and hopefully monday i can get the SAS on and the rear lift on and its done for now....
Old Jul 25, 2007 | 04:37 AM
  #69
chimmike's Avatar
IMO it's much easier to unbolt the upper a-arm and torsion bar instead of having to cut that off. It's simply 3 bolts for the a-arm.
Old Jul 25, 2007 | 05:47 AM
  #70
Got the rear lift today
the OME 863's are HUGE im gonna have to seriously drop my rear axle down to get these bad boys in.
Old Jul 25, 2007 | 06:14 AM
  #71
chimmike's Avatar
did you get the panhard drop bracket? I picked one up and will be installing it with my coil spacers.
Old Jul 25, 2007 | 06:38 AM
  #72
yeah a 4" pro comp panhard which is perfect because the angle its at now without a panhard is just ok to not hit the tank with 3" of lift so another 4" with the 4" panhard will keep it at the same angle hahah thank god cuz i dont feel beating the crap out of my gas tank hehe
Old Jul 25, 2007 | 03:04 PM
  #73
Axle is DONE!
i finished the axle up today she is lubed and looking good and ready to go on the truck
Old Jul 26, 2007 | 04:46 AM
  #74
chimmike's Avatar
looks good
Oh, for the rear coils: coil spring compressors, disconnect the panhard, and that ought to make it easier to throw the springs in.
Old Jul 26, 2007 | 04:47 AM
  #75
Marc P's Avatar
Wheres the diff protection??
Old Jul 26, 2007 | 06:42 AM
  #76
the diff protection isn't welded on yet the axle gusset isn't either i just hammered it in place haha
Old Jul 26, 2007 | 06:59 AM
  #77
chimmike's Avatar
actually, you should have welded all that stuff on before assembling the axle.
Old Jul 26, 2007 | 07:25 AM
  #78
why its not going to warp anything or harm anything if anything you throw a towel over each knuckle to keep the slag from getting on it.
Old Jul 26, 2007 | 08:28 AM
  #79
chimmike's Avatar
well, for one, on the ring gear it could cause some unnecessary heat in there, and the gaskets and stuff on the knuckes....generally it's safer to weld all that stuff on before assembling it.
Old Jul 26, 2007 | 04:16 PM
  #80
Hanger is welded
Got the hanger done today my brothers friends brother owns a meineke so i got it done on a 220V MIG welder for free which was nice hahaha anyway he did an OK job its deffinetly not going anywhere thats for sure.
