shackle question
shackle question
i have a 1986 toyota 4runner that i am planning on sas soon. I have gotten together most of the things to do a sas and have read lots of builds, but the only thing i have been wondering about is does the shackle mount for the front axle have to be put into the frame or can you mount it below the frame with a mount like on the back. The only reason i am asking is because i do not have anything to cut into the frame with. thanks in advance
I bought a fairly cheap hole saw from homedepot and a used a cordless drill and that set up cut through the frame fairly easy
mounting the shackle hanger under the frame will give you a nasty pinion angle if you don't lower the front hanger as well
Flying91
45
Apr 11, 2024 04:39 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
Shagool22
Aug 14, 2015 12:24 AM
