SAS and excessive leaning
Old Jun 26, 2007 | 05:35 PM
Kaleb's Avatar
I have a SAS'd 2nd gen 4Runner along with a rear leaf conversion. Everyday I get at least 2 people telling me my truck leans like crazy when I go around corners. Just wondering if any of you other guys with the same setup are having this issue. Is anyone running sway bars with this setup? if so how does it do? Could it be a shackle angle problem?
Old Jun 26, 2007 | 07:16 PM
Marc P's Avatar
People think mine is going to tip over. We are just top heavy with soft suspension....
Old Jun 26, 2007 | 07:41 PM
Ganoid's Avatar
Thats just the nature of the beats if you want soft flexy suspension. Sometimes I think my mirrors drag the pavement when I go around a corner too fast.
Old Jun 26, 2007 | 07:57 PM
4RunnerKid's Avatar
depends on your spring rate, shocks, height, etc. mine's a little tall, but with the springs i'm running it's actually pretty stable around corners... better than it was with IFS and no sway bars IMO.
Old Jun 26, 2007 | 08:52 PM
blainelukens's Avatar
mine leans alot around corners, although it was what I expected so what can I say the rears up front are soft
Old Jun 26, 2007 | 09:00 PM
881stGenRunner's Avatar
my brothers leans to the passenger side just sitting there.
Old Jun 26, 2007 | 09:24 PM
Tofer's Avatar
Sponsor
mine is tippsy as hell with my rack.. i've taken my rack off for gas milage reasons and its much more stable. i've thought about running limiting straps to keep her belly side down.
Old Jun 27, 2007 | 02:55 PM
ORS's Avatar
ORS
That is very common, seems like most of the trucks that have good wheel travel and articulation also have quite a bit of body roll. It's just part of having a truck that works well off road; there will always be a trade off.
Old Jun 28, 2007 | 02:38 PM
Kaleb's Avatar
Thats kinda what I thought. It does not bother me, but what does is all of the people telling me that my truck leans around corners. I have a spool in the rear so when I have to turn into a parking spot my rear axle gets pulled out to one side a bit, which makes my truck lean. Has anyone installed sway bars on an SAS'd truck?
Old Jun 28, 2007 | 03:18 PM
Elvota's Avatar
Mine works pretty good... I don't drive it aggressively on asphalt corners however.
When I did my road trip to Utah I put a shuttle box on top and that got down right spooky with crosswinds. Was like trying to drive a weeble-wobble at 65 miles per hour. I had to let off the gas many times just to keep things straight. I think I had about 65 lbs up top though...
YT'r "Rebelnoclu" has installed a sway bar in the rear of his leaf sprung 2nd Gen 4Runner. I think he is running 37's and has a full internal cage... so pretty heavy and high. Try to PM him if he doesn't post. I don't think he is on YT to much.
He says it works really well, can actually help flex off road. He wheels aggressively with a lot of experience... so would be a good brain to pick. I'll probably copy his setup when I get some more time and funds.
Or I might just chop the back windows/ roof off to save some weight.
Old Jun 30, 2007 | 08:01 AM
awsumdc's Avatar
Just put a sway bar on it like the ones from Currie Ent, The " Anti-Rock " and that should take care of your probelms.
I dont have one on my '05 Taco and I'm on coilovers. It doesn't bother me though because I didn't want a sports car.
Old Jun 30, 2007 | 09:35 AM
Beast's Avatar
I have been know to have my inside rear tire 6-8 inches off the ground, full throttle around a corner
My truck flexes over and then is stable again
(mount heavy things, high lift, spare, tools AS LOW AS POSSIBLE!!!!) = stability
Old Jul 12, 2007 | 07:58 AM
anthony1's Avatar
I put the stock rear sway bar back on a few months ago and it does wonders for the truck. I had to make a block to clear the cable locker assembly. The end links I have is from 4" pro-comp kit.
Before that, it was leaning a lot.
Old Jul 12, 2007 | 09:09 AM
WATRD's Avatar
I joke about dragging mirrors and about the slalom not being my favorite event... same here, lots of body roll. After a while you used to it and it seems normal.
People comment and I just tell them it is the cost of having that much flex. I run adjustable shocks, so I crank them up on road and that helps considerably, but I can't bring myself to put sway bars on.
Old Jul 12, 2007 | 09:28 AM
Tacotex's Avatar
I would'nt use a rig with that much lift as a DD, at least not without a cage. Highway speed rollovers can wreck your whole day
Old Jul 16, 2007 | 03:33 PM
ORS's Avatar
ORS
Yeah, didn't notice you said "spool". That probably contributes a large amount to the lean. It puts so much side-side load into the rear end on pavement, it's like having axle-wrap sideways. Hope you get the sway bar thing worked out, good luck!
Old Jul 16, 2007 | 04:22 PM
Kaleb's Avatar
The spool only makes a difference in low speed situations where I must turn. Like turning into a parking spot. I installed the spool after I SAS'd my rig. It has made no difference in the lean other then parking. As for the sway bar, I am just going to let it be as it does not really bother me.
Old Aug 22, 2007 | 06:27 AM
SteveO's Avatar
Something to get used to.
When I go around corners in town, sometimes I'll cut it a little tighter. People in front of me start opening their eyes real big, thinking its going to roll towards them. Lots o fun.
With as much flex as I get on the trail, its fun to get nearly this amount of flex on the road in a turn.
Old Aug 22, 2007 | 08:46 AM
idayota's Avatar
have the same thing with my 84 runner...just one of the costs of dd a flexy rig. its fun to get in front of someone on the way to a trail who has never been wheeling with us before and see what he says over the cb on the logging roads to the trail. i dont drive it like a sports car, but more often than not he'll get on the squawk box and warn me that it looks like im gonna fall over...then we hit the trail and everything works great and he sees why the suspension is as soft as it is. all in all, dont worry about it.
oh yeah, you ever try to pull into a parking spot, back up three feet while your straight, then pull in again? might help unload the rear spool/suspension.
Old Aug 22, 2007 | 09:17 AM
UKMyers's Avatar
You outta see mine on 37s with a 2" body lift!! I swerve all over the road. People usually steer clear. Going over the passes on Hwy 4 and Hwy 88 up here in the Sierras are sporty!!
