Replaced and relocated transfercase cooler
Old Nov 25, 2008 | 09:14 PM
Marc P's Avatar
After my axle swap I found the transfercase cooler in an odd location. I had to space it out away from the shackle on the passenger side. It worked ok....until I got the headers installed. I wasn't sure what I wanted to do with it....do I by-pass it, buy the Downey relocation kit, or blow up my truck???
Found a solution at Summit....frame mounted cooler! Now I am ready to wheel this desert season.
Before the headers...
New setup...
Old Nov 28, 2008 | 10:42 AM
cherokeechief79's Avatar
very nice!
i have to do something similar.did you just cut the stock hoses and hoseclamp them to the new fittings?or dsid you run new hoses?
Old Nov 28, 2008 | 04:47 PM
agusgus3's Avatar
I'm not too sure how much efficiency your going to see out of that cooler with little to no air flow through the fins even with the vehicle at speed... just my .02
Old Nov 28, 2008 | 07:46 PM
Marc P's Avatar
Yes, I just cut the hoses and clamped them. The t-case has very little pressure, so I am not worried a bit.
No airflow?? how can you say that? it is spaced away from the frame and probably will cool better than it did in the lame stock location. Plus it is way bigger than the stock cooler.
Old Nov 29, 2008 | 09:22 AM
Blizzard's Avatar
Nice Marc!
I put a round cooler behind my custom bumper. Mine is for the auto tranny.
Cheers,
David
Old Nov 29, 2008 | 10:27 AM
agusgus3's Avatar
Spaced from the frame is good and definitely the size upgrade, but having it perpendicular to the flow of air doesn't do much, the way David had his, is something to be considered.
I like the black and clean look.
Old Dec 4, 2008 | 04:45 AM
4xJedi's Avatar
I may have missed it but, what are you using for a pump?
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
1994toyota
Jul 17, 2015 03:03 AM
Coreyr384
Jul 10, 2015 11:13 AM
Snort
Jul 9, 2015 03:58 PM
