My '94 4Runner SAS
Old Aug 20, 2008 | 10:31 AM
  #101
coolthew's Avatar
I am so jealous of all you Europeans with you diesel engines...
Old Aug 21, 2008 | 12:01 PM
  #102
-MaTTi-'s Avatar
Well done! I like especially the scoop. Itīs like itīs always been there.
Itīs so different now, compared what is was a year ago. What a huge improvement.
Old Oct 28, 2008 | 05:00 PM
  #103
cherokeechief79's Avatar
VERY NICE WORK
what happened when you ran the u joint shaft like this?i noticed u pointed the pinion up but ran just 2 u joints.i will have about the same lift in the rear when finished and was wondering if i should point the pinion up and run a lengthened front cv shaft or if i could get away with the u joint shaft.
Old Oct 28, 2008 | 10:13 PM
  #104
Blizzard's Avatar
Hello,
The drive shaft in the picture is the stock one, only used for setting the angle.
I found a 3rd Gen 4Runner in a yard here (The 3rd Gens were never sold in Spain) and I took the rear DS from it. It's a CV and the lenght was almost perfect. Had to shorten it a little when I did the auto conversion.
Ah, and I found a high pinion E-Locker out from a 80 Series Land Cruiser for the front hehehe
My stock birfs won't be lasting very long...
David
Old Oct 29, 2008 | 02:43 AM
  #105
thanks for the info!
Old Oct 29, 2008 | 02:47 AM
  #106
yotaman's Avatar
Originally Posted by cherokeechief79
VERY NICE WORK
I ran my SAS'd truck like that for a few days (after the SAS and rear leaf swap) until I got my CV shaft made.
It vibrated my teeth like crazy but worked. No way in hell I could go over 50 mph with it like that.
Old Oct 31, 2008 | 07:21 AM
  #107
cuatroxcuatro's Avatar
It vibrated my teeth like crazy but worked. No way in hell I could go over 50 miles per hour with it like that.
Were you running dual tcases?
Old Nov 6, 2008 | 07:00 AM
  #108
Blizzard's Avatar
Hello, a bit of refreshing.
This is some of the stupid things we've to do in Spain to legalize my truck.
Obviously that bar will come off once I legalize the truck.
Fender flares and mud flaps
Aiurbag supports
Cheers,
David
Old Nov 6, 2008 | 08:05 AM
  #109
sweet!
maybe i missed something but what are the airbags for?
i was also looking at your custom xmember and was wondering if you dropped your driveline down for better shaft angles.
Old Nov 6, 2008 | 08:28 AM
  #110
Blizzard's Avatar
Hello,
The airbags are for the rear axle. With dual fuel tanks, rear wheel carrier, the bumper and all the things you take on long trips would help a lot.
I've not dropped the driveline, made custom crossmembers for the auto tranny (My truck was manual) and for the gas tank (Someone went crazy with the plasma and cut the stock hanger). Now I can put a UHMWPE skid and cover the tranny and the stock fuel tank+exhaust.
David
Old Nov 10, 2008 | 01:31 PM
  #111
Blizzard's Avatar
Hello,
Today we took the pics for the legalization project. This means the truck has fender flares, mudflaps and that stupid rear bar...
And the rear airbags mounted and working. They are amazing, the rear lifts 6-8'' when airing the airbags
David
Old Nov 10, 2008 | 02:43 PM
  #112
very nice work!
Old Dec 1, 2008 | 12:05 PM
  #113
904_runner's Avatar
Any updates?
How are you liking the TG kit?
Old Dec 3, 2008 | 01:45 PM
  #114
Blizzard's Avatar
Hello,
I've the air bags system working and it's very nice.
The TG ki8t is good quality, I only have compliments about the long slip yoke being bad machined (Off-centered).
Will post pics as soon as I can.
David
Old Dec 8, 2008 | 12:17 PM
  #115
Blizzard's Avatar
Hello,
Time for new pictures...
Put the rear airbags inflation nozzle in the back of one rockslider. I'll be putting an in-cab inflation system in a future.
At 14.5 psi they are already lifting the back
I relocated the winch solenoid pack over the frame in the passenger side
Installed a CB speaker as I put the CB in a double DIN center console (My truck had a single DIN console from stock)
Also installed a mirror with lights in. European 4Runners didn't have those lights... Swapped them to 4x3 LED panels
The CB installed below the computer touchscreen
Console for the auto gear stick
Installed a Warn power interrupt kit for the winch
Made a sandwich plate for the bracket I made to support it
The rear airbags at 29psi
Look at the shackle angle hahaha
And put the winch plug in the bumper. Also wired the in-cab control
See you,
David
Old Dec 14, 2008 | 02:19 AM
  #116
Blizzard's Avatar
Update:
Threaded 4 holes in the rear bumper
To put a pair of plastic discs I made in the lathe
This is their use
The latch
I've to finish the fender flares over the bumper
Not my spare hehe
This is the license plate holder I made using one of a Toyota LJ70
The rear part. It's bolted to the wheel
With a borrowed spare the holder is separated but not with my spare
With lights
Made two reinforcements
With my wheel
And with a 35
Made two nuts than can be undone with the hands
And also took it out to flex it.
The only remaining thing is install the front HP E-Locker.
Hope you like it
David
Old Dec 14, 2008 | 10:45 AM
  #117
yotasavg's Avatar
you don't have to run with all that flare crap forever do you? just to pass inspections?
Old Dec 14, 2008 | 05:06 PM
  #118
agusgus3's Avatar
Sweet rig!@! Just one question, where did you get those projector headlights? I would love something like those, but there is such a crappy selection for 2nd gen Runners here in the US
Thanks
Old Dec 15, 2008 | 01:32 AM
  #119
Blizzard's Avatar
Hello,
I've to run the flares if I don't want to get ticketed... Also they prevent the truck to get dirty with a little of water on the road hehe
The projector headlights were custom, they're from Hella, I made the supports for them and I've to smooth the grill over them.
David
Old Dec 17, 2008 | 08:20 AM
  #120
Very Nice Work David!
