my 2wd to 4wd 1986 toyota exta cab turbo build thread!
#121
i am guessing there may be alot of wires to deal with.. i think the easiest rout would be to swap the whole engine/charging harness into your truck or just use the 3.4 main realay/fuse box. i dont have much experiance with the 3.4 but i do know wires
#123
#124
i think it only has 3 correct? two main and one for checking catalist perfomance. i would leave only the three, the two mains are your concern they are the computers source for correct AF ratio in closed loop. the other one.. eh just run it behind a cat on one side.
#129
sitting in my shop, motor needs wired and i need to do exhaust and a few other things. i have another e-locker lined up for the front but i might just sell my whole truck, i need somethin to drive but i know if i sell it ill regret it in like 2 days cause ive built this truck how i want it and it would be very hard to make another with the same parts for as cheap as i have and i have countless hours into it. i dont know what to do!!!
#132
#137
i know where that mc-crapples is!.. i am not sure on the wiring, the 5vz is obd2, not as easy to hack apart. you pretty much just need to get powers and grounds to were they need to go, and just make sure you have all the harness including the charging side..
if you do there really isn't much to wire up. just hook up your powers and grounds..
#138
#139
lol... sorry buddy, between work and wife/kid i don't have much time after work. i think the soonest time i could make it by would be next weekend. do you have access to a printer? if so i have access to all data and from there we can out what wires go were.
flex with NO motor trans or t-case
my shop!
another factory turbo truck on the right!
i love my runner!!
