Moving axle forward
Old Jun 7, 2009 | 10:59 AM
YOTA666's Avatar
Moving axle forward
Hey guys, im about to start on my first SAS and I was just wondering what is involved in moving the axle forward?
Is it just a matter of moving the hanger forward and moving the rear shackle mounts forward as well?
I've got a trailgear 5" HD sas kit so I dont wanna go forward so much that I can't use the steering system that comes with it.
thanks!
Old Jun 8, 2009 | 09:05 PM
Toyotero's Avatar
I've not done a SAS yet, but from what I've seen, you'll probably have to move your steering box forward so that the drag link and tie rod don't hit.. or worse the pitman and tie rod...
Alternatively, you can get a flat pitman arm that might help (Cruiser pitman maybe) or a shorter one.. of course, then you'll have 3 pt turns at every corner...
Or who knows, with 5" springs, draglink/tierod, clearance might not be a problem depending on your driver's side articulation when compressed.
Don't forget to check the slip yoke on the drive shaft... 2" forward on the axle will required almost 2" on the drive shaft to keep the same yoke position you have now.
- Toyotero.
Old Jun 9, 2009 | 05:53 AM
4Crawler's Avatar
Right off the bat, those springs will move your axle forward 2" as compared to using a stock front leaf spring. To go farther, you'll move the front hanger forward on the frame, I think most of the kits offer stock and 1" forward mounting options. Then you'll probably need to move your steering box forward on the frame as far as it can go.
Old Jun 9, 2009 | 03:51 PM
YOTA666's Avatar
alright i think im just gonna do it according to the instructions for the first time lol. Thanks for the help!
Old Jun 9, 2009 | 04:05 PM
fillsrunner4's Avatar
At the bottom of my sig is a link to my build threads the 4.3 build on the last or second to last page tells you and shows you how to do this. Gotta search this stuff cause the info is out there
Old Jun 10, 2009 | 12:25 AM
4RunnerKid's Avatar
you can also re-drill the perches for another 1.5" or so... i almost guarantee you'll have to move your steering box though
delmert
Sep 30, 2015 04:34 PM
Scotto6591
Sep 1, 2015 03:24 PM
ripp96
Jul 25, 2015 02:32 PM
Backcountry411
Jul 24, 2015 08:06 AM
crashburnoveride
Jul 10, 2015 06:39 AM
