IFS Front Driveshaft
Old Apr 29, 2007 | 10:09 PM
captwalker87's Avatar
Besides length, is there any other reason that I cannot use the IFS drive shaft to accomdate my low pinion solid axle swap? I would prefer to keep the double cardian at the transfer case. Just to extreme of an angle? I am sure this has been covered, I just cannot seem to locate the exact answer I am looking for. Thanks.
Old Apr 29, 2007 | 11:12 PM
Elvota's Avatar
It's not only the length of the DS but the amount of slip it has. You'll need maybe 6" to 8" of slip with a SAS. The IFS shaft has maybe 3" max. PLus you'll need an longer DS from end to end.
The stock double cardian needs to be modified to allow for more aggressive working angle as well. Most ditch the DC for a standard CV at both ends.
If you are on a budget, a long slip DS can be made with two pieces of hitch stock. Should be under $60.
Old Apr 30, 2007 | 12:15 AM
Tofer's Avatar
Sponsor
here's mine http://www.eakland.net/joey/DSC_1481.JPG
and for the record thats mud not rust
Old May 1, 2007 | 05:41 PM
Superflex84's Avatar
The IFS DC does not have as much movement as the 79-85 DC.
I am dealing with this problem right now. I think I'm going to use a 85 shaft with a 8" slip(for use on my 3" trail gear kit).
make a square shaft, or find a good 85 or older front shaft to add a slip to...
Old May 1, 2007 | 07:27 PM
Phalanx's Avatar
I used my IFS drive shaft with my SAS. I had the 8" spline from Marlin installed and I had to grind down the CV joint a little.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
deepmarsh
Aug 6, 2015 03:44 AM
coffey50
Jul 28, 2015 10:55 AM
scottyg486
Jul 19, 2015 05:34 PM
